silviaS13lover wrote:oh know that i think about it, their is a pulsar chillen at this local junk yard. lol. so can i get a picture of the vac reservoir? please, and to make sure, i can use the ignitor chip and maf out of that car aswell. thanks..
Heres the ignitor you want.
http://cgi.ebay.com/ebaymotors...80797
The one you posted is from the newer Q45's.
For pics of the reservoir and the "how to", look here:
zerothread/225309
If your junkyard has the correct pulsar (nx se 1.8L) I would take a printout of all the vacuum components and grab everything similar from the junked one...just remember it will be the same components just arranged in different spots since its front wheel drive. As I recall most of the parts were under the airbox (had to take it off to get to the parts). The vacuum canister was near the firewall I believe. You might also grab the injector resistor which is on the firewall also incase your motorset doesnt come with one.
Your MAF question.....dont use Q45.....unless you have have SAFC or socketted ECU with ROM programmer. Even then, Q45 maf isnt all that. I would go with KAE or buy an oem maf from someone on here.
-m
