No, you will not. Compression does not have a effect on spool. The motor makes more power off boost, so people think it spools faster.ca18datsun510 wrote:you will also see boost a little quicker.
First of all, sorry you damaged your $500+forged pistons/rings. Second, have you determined how you screwed them up in first place? It is important to figure out what caused damage to those pistons. I would say too much bust for an extended period (W.O.T.) could be one. I would also take a guess and say you either melted one or some on the intake side or cracked one or some of the ringlands on the intake side (only you know what really happened). So I guess the million dollar question, why in the world would you want to jack-up the compression in your engine, when you haven't figured-out what caused the destruction of your current pistons.Vlade wrote:Hi All
I currently have some 8.5:1 CP pistons in my engine, but they sorta got a bit damaged now I need to replace them.
What is the preferred compression ratio for the CA18DET?
Reason why I ask I can get a nice deal on some 9.5:1 Forgies but, the compression ratio is way bit higher...
I know the car will need a re-tune but this ain't a problem.
I have done the closest "back to back" test you can do. Same motor, same trubo, same boost pressure, same everything besides compression (9.0 vs 10.0). The spool was the same besides the fact the higher compression motor made more power off boost. I tuned both motors.ca18datsun510 wrote:yes it does, higher compression increases velocity, and will help spool up.
i believe it is float, who has higer compression pistons and has a real world example.
also, compression has a lot more aspecs involved then just what octane you run. timing, air fuel ratios's, etc all play into that.
higher octane is better of course.
I too have done a similar comparison. I can honestly say that a CA T25 w/a slower spooling SSAC equal length manifold spools faster w/9.5:1 compression ratio than the CA T25 on the stock manifold at 8.5:1 compression ratio. The boost onset is much more linear as well with less of a "rush" and the throttle is much easier to control.good morning wrote:
You are correct, but this a street motor. The biggest problem he will come across is octane. Timing is a by product of the motor, BTW.
I hope that cleared things up
Manifolds have a big effect on the motor. I understand your experience, but you see were I am coming from.float_6969 wrote:I too have done a similar comparison. I can honestly say that a CA T25 w/a slower spooling SSAC equal length manifold spools faster w/9.5:1 compression ratio than the CA T25 on the stock manifold at 8.5:1 compression ratio. The boost onset is much more linear as well with less of a "rush" and the throttle is much easier to control.
Sounds like the ideal thing to do in the case of the CA18DET. Start adding cams and go fast crap and the spool-up gets slower. I say, enjoy the engine for what it's worth including it's characteristics. It likes to be revved, so stop being wussies and revv the biotch to get the boost you need .c-rad wrote:I dunno about you guys, but if I want my car to spool fast, I just downshift.
Your tuner is giving you good advice.Vlade wrote:Yeah I also think they don't look too bad... My tuner reckons they shouldn't be reused for reliability and possible "hot spots".
i would agree with you if it was like a cavalier or escort or some daily driver status car. but in a project/toy/performance car, i wouldnt risk it.ks13 wrote:Id prolly reuse those pistons, depending on how deep those pits are (pics dont show) you could easily clean those up with some 1000 grit, followed by scotch brite, followed by some emery paper.
float_6969 wrote:Every time you post, my quote just makes more, and more sense...
hypocrit much float?ca18datsun510 wrote:
