capowered240 »
https://forums.nicoclub.com/capowered240-u27587.html
Fri Jun 01, 2007 5:36 pm
If you have a dsm injector resistor pack then what I did is cut both plugs off then sliced them together. On the dsm one you should have five wires total, 1 white wire and 4 black wires. On the harness side you will have five colored wires, Red, yellow,blue,green, and white. So you want to connect the red wire on the harness and the white wire on the dsm resistor pack together. the other wires you can just connect them anyway. They don't get wired a certain way. One black wire to each color wire. That is what I did and it works fine, no problems.
I think it is the pulsar with the 1.6L ca in it that has the resistor pack for the injectors. If you have one those, you should just be able to plug them together, no problem.
Hope this helps.
