Once again, a CA18 owner stating "facts" with no factual evidence.themadscientist wrote:Flow bench is ****. A running engine with opening and closing valves, the airflow starting and stopping and starting again is nothing like the steady state of a flowbench.
The SRs valvetrain is terrible by comparison, no can defense danielsan.Does it work? Yes it does work, Nissan builds good motors. Both motors rev, I never got the whole "revability" thing myself and both motors will suffer rev limitations based on the hydraulic components in their valvetrain but cam on bucket is better. The undercam rocker thing is an L design revistited but made worse by having one arm actuate two valves.
The CA has all the stops pulled out, it was cutting edge for it's time. No it was not a copy of the 4AG, that is a pretty assinanine statement. The whole design of the SR is "good enough". That's why it's so often pointed out to be cheap.
one more part to flex, one more part to break, one more part to go out of adjustment. The fact that I have to explain it to you speaks volumes. If you could perform the same work by picking up a rock directly or use a lever on another rock to do the work, which is better? Wait, don't rush to answer, the other rock that you are using as a fulcrum is at the opposite end of the lever, you must pick it up by the middle of the lever. Think, I know it might challenge you but give it a shot. (take note, the work in the engine is push rather than pull but the work is the same in either direction)AmoebAssassin wrote:Can you explain to me why one cam lobe actuating two valves is a detriment? Can you explain to me why bucket-tappet valvetrains are better than rocker valvetrains?
I just did, reveiw and absorb.AmoebAssassin wrote:Can you explain to me why the SR's valvetrain is "terrible by comparison"?
Well considering I was out there on the street fighting all manner of engines of that era in country I think I have a better understanding of what was on the street than you. For it's time, the design of the CA was what other manufacturers were working with. The SRs design however is not revolutionary, it is actually a step backwards. The CA was in tune with the time it lived in, the SR was old when it was new. This would be like V8 guys touting the return of pushrods. Maybe that metaphor is lost on you since I had to earlier explain the disadvantage of adding extra parts to the valvetrain.Probably not.AmoebAssassin wrote:Do you have a broad enough understanding of 1970-1980 engine design to state that the CA18 was "cutting edge" and not be doing anything more than blowing more hot air?
Study some, port velocity in particular. An engine does not flow in a steady state. I know engine builders on both sides of the fence, the facts I have studied in technical manuals and what I have personally seen from both sides of the argument show me that a measurement of a machine based on a condition it will never see used as a tuning guide is a fools exercise. These same experts would have you stick a tiny exhuast housing on a car for response. Then they cannot understand why a housing designed to make power at 2000 rpm falls off at 7000. I don't beleive what people say, I watch what they do. I don't look at a parts list I run the ****er and see what it does. There is a reason I can do the things I do. There is a reason I can take an L20 and knock out an FJ20, there is a reason I can take an RB20 and hold off an RB25, there is a reason I can take a CA18DE and run down an RB20DE****INGT son!I would like to have a nice discussion about the two, their strengths and weaknesses because neither is the perfect weapon but if you want to have a pissing match instead, that's fine too, you will get wet. kissesAmoebAssassin wrote:Oh, by the way -- go to any respectable engine builder and tell him flow bench ratings don't matter. Then watch as you get laughed out of his shop.
No but I'd rather you do that than snicker in seclusion and bash a motor that is equal to yours. There should be a neutral sticky where all motors are discussed. There is no reason to continue this thread.r34 gtr wrote:i dont go barging into the SR forum talking trash. get out of my house!
That is a good point redtop, I agree with you. I would love it if nobody bashed anybody, I have yet to encounter a Nissan motor that was not a good one. Peoples emotions get involved when discussing them because they are such personal choices, I don't think we could ever have that. It's like brothers fighting, dumb unnecessary and in the end pointless.redtop91 wrote:
The difference is, I dont go around making fallacious or dubiously supported claims, whereas you do. I simply asked you to prove something to me in a logical, scientific manner and you could not.themadscientist wrote:As said by the SR guy with similar credentials
Reading is fundamental, try it again. You do exactly what you would denounce me for. Hipocracy is unattractive.AmoebAssassin wrote:
Apparently you couldn't relate to them in second grade, nor now. Congratulations on your schooling, it means you read books. I read books too. I know too many people in too many diverse feilds who hide behind a diploma but can't do **** to back it up. I see "certified technicians" do dumb **** all the time. It doesn't mean a thing to me.AmoebAssassin wrote:I'm two semesters away from my B.S. in Mech Eng (which I'm assuming is more formal education than you have in the field) so you don't have to coddle to me with dumbass examples that I could maybe relate to in 2nd grade, kthx..
Again you failed to read. Better learn how I assume they still test you on things before they give you sheepskin. The steady state is in reference to the flowbench not the cam. Try again.AmoebAssassin wrote:Okay, let's use your own argument. Picking a rock up in "steady state" is a lot different than a camshaft revolving at engine speed. Engines at speed present lots of variables to consider, so let's consider them..
That's a fun one, I'll play along. All I have is a kitchen scale but I will go home tonight and weigh a CA cam, you weigh an SR one and we will see what we get. We have no way to measure moment of inertia here though but I know of the phenmenon of which you speak. Could we measure it I may have to award you a half point. The CA cams have narrower lobes compared to the SR though, it is tough to say which has more rotational mass, they would likely score very closely to each other on that.AmoebAssassin wrote:Firstly, you reduce both the mass and rotational moment of inertia of your camshaft in the SR head. Since there are fewer lobes, there is less mass and it is more centralized around the rotational axis of the motor, allowing the camshaft to accelerate more quickly and with less resistance..
Now that is a solid point and worth mention, you definately earned that one.AmoebAssassin wrote:Additionally, with the SR's actuation design, there is less friction than in the CA18 head. With only one friction surface between cam and rocker for two valves, you've halved your friction surface, and thereby reduced frictional forces and head/cam oiling requirements..
In general theory possibly but in actual use the SR ehxibits pronounced valve guide wear vs the CA and RB which are cam on bucket. This means more friction which will likely bring you back a step from the gain you made above. It may be the angle that the valve is on the SR, it may not be an all-the-time occurance with the fulcrum type valvetrain but it happens here.AmoebAssassin wrote:While SR20s may have more reciprocating valvetrain mass than CA18s, they more than make up for it by the inherent ability of a rocker arm setup to run higher lift profiles, and more aggressive valve opening profiles. With a bucket-tappet setup, you find a limit when your valve ramp up is so steep that you essentially start slapping your cam opening face against your valve bucket. Also, your off-axis (sideways) loadings are much larger in cam on bucket systems than in rocker systems, increasing friction and wear between your valve stem and valve guides.
It don't take a degree to see what is out there. The CA was on par with it's competion at the time in all design features, the SR is retro. Sorry if the dumb guy who doesn't kiss your *** because you read a textbook and think you have all the answers won't take the opinion based on what classes you took.AmoebAssassin wrote:Oh boy, street racing sure gives you some sweet credentials on engine design, right? By the way, thanks once again for attempting to make an argument with no numbers or design analysis to support your claim..
I never said the pushrod was bad, just not as good. Man you don't read at all do you? SOHC motors suffer the same problem regarding independent tuning of exhuast and intake timing, not a pushrod only issue.AmoebAssassin wrote:Oh, and by the way, there's nothing wrong with pushrods. Its not elegant, but it is a simple design, and it works well. The only disadvantage of the system is it does not provide for independent tuning of exhaust and intake cam openings and closings without buying a new cam.
Adding parts when it is unnecesary of course. Were the pushrods to go away the motor would likely do better.Let's see You have a 5.7 liter motor making 500hp (does math, curses himself for not getting that engineering degree so he could be all self-impressed like somebody) That's 87.71 hp per liter. Now somebody find me some particulars on it, compression ratio etc because here is what I put up against it the weak, pathetic old CA18DE(no turbo).1.8 liters making 150hp, (help me dude the math just hurts my highschool-educated brain and you are so smart) 83.33 hp per liter. This is in 1989 with 9.5:1 compression and grandma camshafts compared to the vette.AmoebAssassin wrote:Adding parts to your valvetrain is not bad, as long as you properly engineer them. Go tell a C6 Z06 owner that his LS7 is crap because it has rocker arms and pushrods, even though it makes 500+hp and spins to 7000rpm. If he gives you flak, you could probably street race him and shut him up, right? Because you're what, like, 40 and you still street race? Man you're awesome.
The only way to truly see what the head will do is to put it into operation in the real world. You are measuring a situation the engine will never see I suppose you would bore a block without a torque plate as well. It measures perfect sitting there on the floor smart guy number one, well smart guy number 2 lets put it together then. The head doesn't live on a vacuum table, it lives on a engine with all types of variables you have removed so you can say "well this one flows more air in the completely unrealistic arrangement than the other one so it must be better". This would be like religiously watching an air/fuel meter and using that as the only guideline and not adjusting it to make peak power in the range the motor will be living in. The dyno is where you tune, with the motor operating in the state it will live in.AmoebAssassin wrote:Here, i've studied a little bit about fluid mechanics, i'll clue you in on something called head loss, and why flow benches DO indicate engine performance.
Head loss describes the amount of energy any given flow in a pipe will lose due (most practically with respect to our argument) to frictional effects over rough internal surfaces, and minor losses due to sudden changes in piping diameter (the interface areas between manifolds and ports, etc.). What a flow bench reveals is how much flow energy a head will dissipate because of it's design and construction. At a standard pressure differential, a higher flowing head robs less energy from flow and thus, has less fluid friction forces restricting flow in the head -- you can deduce then, that there is less frictional resistance in the higher flowing head.
Now, why don't we look at an operating engine, not in steady state, and with valve openings and closings. Since you're interrupting and halting flow with valves, you must have to accelerate air through your head once you valves open, correct? Accelerating fluids in the presence of frictional forces requires the engine to expend more power on it's induction cycle, reducing it's efficiency and ultimate power output. Hence, the head that flows more on a flowbench has less frictional resistance, and thus will be more efficient and prone to making power under actual operating conditions.
Use of flowbenches at standard conditions is a great way to compare different heads, and the reduction in losses you develop by upgrading your valvetrain.
I think my posts in this thread say all I need, yours speak for you as well. I have been respectful when it was called for (everybody else and to your engine by the way) and firm when requested by the others conduct (you). Don't get butthurt. If you read you will see I don't hate on the SR but I am brutally honest about it and I am not afraid to turn that lens inward to the CA. I think you will find I am not an SR hater. I don't really hate any engine, well ok that 1.9 Opel motor was a ***** but that was because the timing mark was on the damned flywheel.AmoebAssassin wrote:Stupid is as stupid does I suppose -- Kudos to you for ignoring what stupid people have to say. A civilized discussion would be nice, but it's very difficult with you condescending to me at every step of your argument.
No ****? 7 liters? my god it's worse than I thought! 71.42hp per liter, haha.kapower06 wrote:And one more thing.The CA did cost more to produce and took more time. time=money to business's.
And one of the main reasons that Nissan quit producing the CA was that the cost of IRON was outrageous in the late early 90's so they had to produce another engine to take the CA's spot, one that was cheaper and faster to build, this is were the SR comes in.
And for your lil comparo of the c6 z06... I personally think its funny that people believe that 505hp is alot. Yes it is alot, but not from a freaking 7 liter motor. Lets see, stock ca18det is putting out 175hp (not whp) thats damn near 100hp/liter. with a simple exhaust and air filter the power is well over 175hp (not whp) then take into example the rb26 or the s15 sr20, they both make well over 100hp/liter. All im saying is don't go making the ls7 seem like the god send motor, SEVEN liters, WAYYYYYY under 700hp? funny?
All in all im not bashing the SR20 or the ls7 just saying that anything can be made to go fast, we all just have different ways of achieving how we get to our goal.
You speak of having the desire to have a level headed legitimate discussion covering the various differences and pro's and con's of the various motors, but aren't able due to TMS's "condescending" post. Yet from my view you are the one that introduced yourself into this thread with condescension.AmoebAssassin wrote:Stupid is as stupid does I suppose -- Kudos to you for ignoring what stupid people have to say. A civilized discussion would be nice, but it's very difficult with you condescending to me at every step of your argument.
Although I'm not currently an engineering major, I have a decent grasp of fluid mechanics as I use it on a daily basis. I work in the pool and spa industry and am quite familiar with the principals behind the behavior of water or gas traveling through a fixed container. The problem with a flow bench is that if the results of the flow bench are the only consideration taken into account, then all "well designed motors" would run hogged out ports, with 2 humongous valves, just like most of the Nascar motors do.AmoeAssassin wrote:Here, i've studied a little bit about fluid mechanics, i'll clue you in on something called head loss, and why flow benches DO indicate engine performance.
Although what you're saying sounds good, you're not backing it up with any numerical evidence. Have you weighed and compared the masses of the two cams? A longer duration, slower ramped, higher lift cam will have a HIGHER moment of inertia due to the greater amount of mass that is being moved around the axis. Also, have you measured to total contact area of the two cam designs? What numerical evidence do you have to support your claim that the friction is less in the SR head? Have you seen the width of a CA cam lobed compared to that of an SR cam lobe? I would venture to guess that it has at least the same, if not more surface area per cylinder than the CA. Once again, what numerical evidence do you have to support the statement that the greater contact area of the bucket lifter negates the gains provided by direct cam actuation as opposed to "lower contact area", levered rocker arm design? I don't disagree with your concepts, I disagree with you trying to make factual statements with no supporting (numerical) evidence.AmoeAssassin wrote:Firstly, you reduce both the mass and rotational moment of inertia of your camshaft in the SR head. Since there are fewer lobes, there is less mass and it is more centralized around the rotational axis of the motor, allowing the camshaft to accelerate more quickly and with less resistance.
There is no better test to dictate an engines performance, than how it performs. If you want to look down on street racing fine. But if you build a motor and I build a motor and yours looks better on paper and mine goes faster, doesn't that mean I still win?AmoeAssassin wrote:Oh boy, street racing sure gives you some sweet credentials on engine design, right? By the way, thanks once again for attempting to make an argument with no numbers or design analysis to support your claim.
Daym! check please.float_6969 wrote:So why exactly are you here? What is your purpose in posting in this thread? What do you hope to achieve?
Do you honestly think that you're going to come in here touting a degree that you don't have yet and show us all the error of our ways? Enlighten us to the engineering marvel of the SR? Do you expect us to thank and praise your for your much desired knowledge?
Although I'm not currently an engineering major, I have a decent grasp of fluid mechanics as I use it on a daily basis. I work in the pool and spa industry and am quite familiar with the principals behind the behavior or water or gas traveling through a fixed container. The problem with a flow bench is that if the results of the flow bench are the only consideration taken into account, then all "well designed motors" would run hogged out ports, with 2 humongous valves, just like most of the Nascar motors do.
Here is something that will make you think a little. I think that we could both agree that sport bikes have some of the highest power to displacement ratios for naturally aspirated motors. Over the course of the last 15-20 years look at the average port diameter or sport bike heads. What you will find is that they have gradually DECREASED the port diameter. I can also tell you that in comparison to straight flow rates on a flow bench, they will actually flow less. But how is it possible to flow less and make more power? Yes, the engine designs in general play a part, but not as much. In fact, what you will often find is that many people who build sport bikes professionally often decrease the stock port size. All of these modifications would make the head look like it should loose power if performed on the basis of the changes noted on the bench. The main problem with a flow bench, and the point that the TMS was making is that you are trying to infer the performance of the head using a device that doesn't in any way, simulate what's actually going on inside the motor. Port velocities, cam timing, valve overlap, reversion, intake and exhaust pulses, and many other variables AREN'T represented on a flow bench. Important variables that could potentially be more important that the information provided by a flow bench. It's not that a flow bench is a poor tool. It's a great tool, it's just not THE tool. It only looks at one aspect of the head.
Although what you're saying sounds good, you're not backing it up with any numerical evidence. have you weighed and compared the masses of the two cams? A longer duration, slower ramped, higher lift cam will have a HIGHER moment of inertia due to the greater amount of mass that is being moved around the axis. Also, have you measured to total contact area of the two cam designs? What numerical evidence do you have to support your claim that the friction is less in the SR head? Have you seen the width of a CA cam lobed compared to that of an SR cam lobe? I would venture to guess that it has at least the same, if not more surface area per cylinder than the CA. Once again, what numerical evidence do you have to support the statement that the greater contact area of the bucket lifter negates the gains provided by direct cam actuation as opposed to "lower contact area", levered rocker arm design? I don't disagree with your concepts, I disagree with you trying to make factual statements with no supporting (numerical) evidence.
Stop being a hypocrite, you berate him for not supporting his arguments, yet you do the same. This thread was started as a means to vent being "discriminated against" by the ever popular, bandwagon, SR crowd. Sure it's a great motor and has it's merits. The same can be said for the CA. It's also true that the SR has got it's downfalls, and so does the CA. This topic has been beaten so many times is makes me ill to think about having another argument about it.
Nissan never build a CA20DET. They never built a high, 4 port head for it. They never gave the CA a decent sized turbo from the factory. With out these things all you have is some crap that you read out of a text book. You can theorize which motor will do better, but at the end of the day there is no way to compare apples to apples, and with out that it's all just speculation.
I fail to see how I am doing what I am "denouncing you for." I came to this thread asking anyone to please verify the hearsay that so many CA18 guys use to tout their own engines or scowl at others using their "underdog" engine choice, and so far nobody has done it satisfactorily.themadscientist wrote:Reading is fundamental, try it again. You do exactly what you would denounce me for. Hipocracy is unattractive.
See above post. I want someone to provide factual evidence for the claims you've all been making for some time now.float_6969 wrote:So why exactly are you here? What is your purpose in posting in this thread? What do you hope to achieve?
I think any SR and CA cam would be good enough for comparison. If I can find one on my end I can at minimum get basic weights of the two.AmoebAssassin wrote:I would actually really, really love to do this! At this current point in time, though, I cannot dismantle my daily driver. I will ask my friends to see if they have any spares but it is very unlikely. In either case, I will likely be getting newer cams this summer, so if this argument smolders on that long, I'll gladly run some analysis on my SR cams before I sell em off.
You earned that, I don't give anybody anything, it was a good point and if I can find an SR cam I can measure the lobe width. The theory is sound but the important part is getting the measurement to plug in.AmoebAssassin wrote:Thanks
It has been evident in SRs that I have seen torn down. It appears to me as if the rocker is shifting around as it works. That's why I wonder if it just an SR thing and not necessarily a design thing in general. Could be an oil change thing, Japanese dudes don't do that as much as they should and most of the popped SRs I see have evidence of shoddy maintenance. Couple this with the lack of good machine shops around here (I was told by every shop I approached they were unable to even change valveguides) and I wonder how many tore up guides are running around in "rebuilt" engines. You should have seen the look on the guys face when I said things like "dynamic balance" and "torque plate". I miss the states sometimesAmoebAssassin wrote:I actually have not heard of this occurrence in SR's -- could you please divulge your source? The rocker arm will absorb the horizontal frictional loadings of the camshaft, whereas on the CA18 the horizontal force is transferred directly to the lifter and in turn the valve.
If you're not BSing me and this wear condition does exist in SRs, it's more likely a valve actuation angle issue than anything else -- this is unlikely, as the actuation angle is very close to 180 degrees, and the amount of side loading a rocker transfers to it's valve is traditionally very low. Perhaps the same you've seen was due to under-oiling or improper engine care. Regardless, I have not heard of this happening and would like to see any valve guide wear pictures if you have any.
I think both camps have silly battle crys that embarrass the more moderate enthusiasts. If I have to hear one more "it's 2/3s of an RB" I might have to smack someone.AmoebAssassin wrote:It doesn't take a degree to see what's out there, but it sure helps to have a firm engineering background from which you can make qualified comments, rather than backyard speculation. I don't have all the answers, nor was I claiming to have them. I merely came here to ask this forum to prove what everyone has been claiming sans evidence on the internet. It's not a problem of me having all the answers, its about the CA camp having little to none.
I should have said up-to-date, I get verbose. Nobody's street engine has "cutting edge" anything. By the time new advances trickle down to the consumer it is already accepted standard. I maintain though that the SR is a throwback to older technology where the head is concerned. The whole chain vs belt debate is not one I involve myself in. I like belt but I have no bad things to say about chain either. Chain works in my L and my FJ (well, not so good in my FJ, ****ing upper tensioner) but I prefer the belt. I change mine regularly though so breakage is not somethin I worry about.AmoebAssassin wrote:The only difference of arguable significance between the SR and CA is the valve actuation mechanism -- and cam-on-bucket design had been around for a good while before the CA18. Can you tell me any other "cutting edge" technology that's on CA18s? Cross flow heads and piston oil cooling come to mind, but again, these technologies have been around before the CA18. Same with EFI, etc. Please tell me what was so cutting edge about the CA18?
Pushrods get it done, no doubt, please don't think I harbor some disdain for them, I don't. Same goes with the SR type rocker arm, the L uses a similar arrangement. I just hold to the KISS principle and the more parts involved the more it worries me.AmoebAssassin wrote:Yes, I knew that, thanks. Mentioning SOHC motors is extraneous information and not pertinent to our argument at the moment. "Not as good" is purely subjective. Just as is said, what works on paper doesnt matter if it doesn't work in real life, right? Well rocker arms and pushrods may be ugly on paper, but they're working for a number of different engine designs, and they have been working well for some time now.
I knew you would do that, boo hiss, I fed you that oneAmoebAssassin wrote:Without pushrods, the motor would not be able to open it's valves!
When dealing with dissimilar motors the only way to quantitatively compare them for the efficiancy and functionality of their designs you must find a common denominator.I clown on those Honda guys too. I am not talking about the total HP but rather the power per liter. The argument for total HP is easy and short, who got more? I think the vette is safe from most four bangers.I can imagine your amusement, when a Honda guy would get uppity about their whatever horsepower per liter I would remind them that while good, they only had 1.6-1.8 of them. We are discussing design so it is relevant, were we discussing maximum power output the motors size and displacement would indeed be irrelevant.AmoebAssassin wrote:Ah, HP/L arguments -- the consolation prize for the man who can't make actual power. The funny part is, I bet 99% of the people reading this thread right now have made fun of honda tuners for using HP/L arguments in the past.
Because we are not talking about total hp but rather the functionality of the various designs and their contribution. I'm not hating on the V8, I am from musclecar roots, I love a lopey V8. Imagine though if they built a big iron american motor that put out the same power per liter or cube if you will as both yours and mine do. I think you would agree 600hp is better than 500, I'd take it!AmoebAssassin wrote:Why don't you please make HP/mass arguments. That's a more solid indicator of performance. And yes, go ahead and hate on LSx engines, knowing that they're not more than 100lbs more massive than your CA18 but make more than double the power, stock, and equally as reliably.
The scientific method would work on anything. You would be able to tell the difference on the flowbench between a ported and unported head. The sticking point I keep comeing back to though is the engine does not breath like a flowbench when it operates so while you have collected consistent comparative data it is useless because it simulates a situation the part in question will never experience.Now an engine on a dyno will gather comparative data that is applicable to the task because it is operating as it is supposed to with all variables present. No flowbench can simulate this and no stack of formulas will completely mimic real world running so it is useless.AmoebAssassin wrote:It also seems as though you didn't read my previous post at all about why flow bench numbers can be used for head comparisons.
Let me remind you that nobody is using flowbench numbers in energy equations to calculate engine power. Flowbenching is a comparitive study, not an absolute one.
Oh, and by the way -- Isolating variables for analysis is called the scientific method. If you want to **** on that, you're going to have to go up against the foundations of science itself. Controlling the environment in which something operates to analyze its performance, or facilitate the study of its operation is an entirely acceptable practice, and has been so since the renaissance.
Well we have two self acknowledged non-haters, sounds win-win to me. I think most CA guys are shoot first ask questions later, true enough. In their defense they have years of disrespect from the the "other side" fueling it. Not nesessarily right but it is true.AmoebAssassin wrote:Me, butthurt? Funny how I'm the one butthurt, when I made one post and this whole CA18 forum has got their panties in a bunch.
You will also find that I'm not a CA18 hater, by the way, and actually considered one for my chassis for a long, long time.
ca18detpowered wrote:I smell a calgary ca18 owners meet.....
hehehehe
Pm me calgary ca owners. Would love to meet up
snowy_s13 wrote:woot Calgary, now if only my Ca wasnt parked....damn
holy crap, i thought i was the only ca guy from calgary on hereCa_Silvia wrote:Thats why the internet is your friend when you own a CA.
Edit: I see your form Calgary also......GO FLAMES!!!
