I started assembling the motor yesterday evening and so far the ARP hardware looks promising, thanks to "CA19DET" for scrounging up part #'s and sharing them with us! You can also use the KA24DE's ARP head bolts on the CA. I tried them yesterday and they are about 2-4mm longer, but everything else is the same. Today I'm going toput on the headgasket and head to verify that indeed the head bolts are perfect. The Pauter rods' clearance in the CA is tighter than the factory rods. I'm going to run the motor without it's timing cover because of the adjustable cam gears and accessibility. I'll leave you boys with some pics, but I'll get back with the results. We just may be in the big league after all
