Emanage came up because it is a unit that's discussions are starting to lurk and it also was used to support the rest of my post. CA20DET= Waste of $$$s. You want big power, don't turn to the emanage nor the super afc as most will blow-up their precious engines and ultimately not have the money to repair them. Emanage may work for some, but hasn't been proven to be a system that's manageable with the CA.dash wrote:if u haven't 'maxed out' the 1.8L, why even consider a 2.0 money pit ?want a torquey 4cyl ? this company nissan, makes a KA24DE... put it back in. Won't find a better "deal". Countless proven combos available.2L CA.... is pi$$in in the wind, at best. Can o' worms
where did the emanage bit come in ?Anyway, several 300+hp street CA18s tuned via emanage blue. 1st time seen it used was on sxoc years ago. Daily driven, T3 @23psi iirc. 300 was all the turbo & injector supported, so I see no reason more power couldn't be made using blue... as folks done with other motors.My blue came from a buddy who ET 7.7 in 1/8th ~3500 pounds, stock motor. Not bad. As with any tuning device, results are directly proportional to users' understanding exactly what they are doing.Better goods out there, no doubt... but EM can/has produced "decent" results
And how much would such a flywheel be?float_6969 wrote:If anybody needs the flywheel that goes with the tomei crankshaft, I've got a brand new one.
horsepower = (torque x speed)/5252dash wrote:Why in the world would any CA18DET enthusiast spend money to go backwards ? Lots of CA beasts redline @8000, with obviously enough torque to deliver the goods. Revving higher won't make them any quicker.Only thing revs will accelerate is wear.... and your next rebuild date
I emailed you.NUT-CSE wrote:And how much would such a flywheel be?
Then why buy the CA, it doesn't have any, neither does the 4A. It's like wanting a tall busty girl, and taking a short skinny girl, breaking her legs and stretching the femurs to get some height, and slapping 4" heels on her for the rest, then shoving implants in her chest and butt to give her a profile. In the end you are left with a freak that doesn't have the quality of what you really wanted and now lacks the reliability it had before.dash wrote: Torque is essential, excessive revs r not.
Agreed on your point that the CA needs boost; almost as if it's a boost addict . I've seen built 4Ags with a 60-1 blower and my god that thing was a slug out the hole. It took forever to wind-up that turbocharger and this was on a RWD GTS with a custom manifold. A 60-1 on a CA18 is bit laggy as well, but when it comes on and granted you have the supporting cast to welcome that kind of boost, it's a wicked burst.themadscientist wrote:
The Tomei 2.0 kit was out for years and I have seen no proof in print, first hand or anecdotal that one ever outperformed a stock stroke CA. The engine doesn't have torque except with perfect turbo selection. You want torque get an SR or a KA. The CA need boost not stroke.
I am with you TMS. I shouldn't have sold my setup either but what can you do. I doubled my money at leastthemadscientist wrote:my rub is not the relationship to the bore but the insane rod angles that result. If the 18 was as tall as a 20 it would make sense.
I miss ya buddy.
