themadscientist wrote:That crank hits everything. even with the tall girdle it smacks the pan rail.
Then it crashes into the base of the cylinders
It will only spin in its original block.
CD20T? Is that the CD20T (or CD20) crank and girdle? Is that girdle separate from the main caps, like the CA18DET's, or is in one piece with them, like KA/RB's?
So, apart from not being able to make half a spin in the CA18 block, does it fit perfectly in the block, is the flywheel mounting the same, is the snout the same? Too bad it didn't work in the CA18 block. The CD20T was sold here in Europe, I could probably find heaps of those cranks in junkyards. Would have been nice if we had something cool that the US guys don't, for a change...
On another note, how different is the CD20 block from a CA18, or CA20? Do you have one handy, by any chance? RWD or FWD? Would the head fit? Are the engine mounts similar?
Oh, yeah, sorry for the old bump.
