because the ECU is trying to avoid something catistrophic. Just like a bank vault without all the right codes you arent going to get anywhere.zache803 wrote:ok but i dont see how this would keep the car from goin over 2k... oh yea and just for ****s and giggles since i fixed the maf wiring i put the mines back on and it threw code 11 but when i put the stock ecu back on it threw code 55
dear god is your ECU tuned for the cams?
can we point out the fact that you have no real clue what you are doing. if you know someone with a CA piece it together stock and see if it will run properly then.
w/o a ECU understanding what you are doing, it will not want to run. fueling, timing, and induction have all got to be in key to run properly.
not like your computer will want to run properly with odds and ends thrown in beyond spec. thats why you have to run a start up disk for nearly everything including a new mouse or keyboard. Once the computer understand...... it works perfect
