What hotparts do you have to mount the HX35 to your CA?PapaBurgundy wrote:Before anyone tells me its too big or to get a t28, the reason I'm asking is that I can get an hx40 cheaper than any bolt on garrett, throw it on my cummins, and put the hx35 from that on my ca and have bigger turbos on both my vehicles for the price of one and a exhuast mani. As the 240 is no longer my DD I dont really care about driveability or bottom end lag. And I'd much rather have an oversized turbo running lower boost than a smaller (t28/t28g) turbo pushed to the max. And I know it will need to be tuned but thats not a big deal. So I guess what I'm asking for is feedback from people who've done it more than hearing the cons from poeple who havent, ah screw it I guess I'll take whatever info I can get. Thanks, Anthony.
Idk about anyone else, but im cheap.... but Im not ebaying a turbo. Some people have had luck with them, but I dont think so.dash wrote:dunno man.... one of the 1st 400hp stock CA18s I recall seeing, ran a H1C holsetYou'd 'think' they would be too big for a 2L dohc or 2.3/2.6L sohc also, but there
r some excellent performing street samples out there with HX & HY35s
speaking of inexpensive turbos, a few fine performing CA18s on oz/nz forums run the
popular ebay T-70.A toyota 1.6L street car also runs ebay T-70 with an upgraded compressor wheel, put
out 550+ hp on a stock supercharged bottom end, 35psi
Reno wrote:
HX35 Ca18det
Quote from iXer Super Moderator: "He used Nissan Sunny GTi cams and a HX35 with 16 cm² turbine housing. With only 0.3 bar boost it has more get-up-and-go than a BPU-enhanced S13 @ 1 bar. The boost threshold seems to be at 2500-3000 rpm, and can be improved upon as he had no boost control. It's put into storage for the winter now so I don't have any more data on it."
Personally i don't like anything lower than a 35 :P
heres more info on it i Believe... don't quote me on that http://www.vems.hu/wiki/index....issan
Matti Juntunens Nissan 200SX S13 "Diesel-Doris"
Status
Engine has been started up, but no tuning has been done yet.
VEMS Genboard specification
1-wire interface: Noignition driver: 4+4 as described on VehicleFitment/NissanCOPsKnock and EGT: Knock and 2 EGTLCD and PS2: YesMAP connection: 400 kPa on-board (5/3 mm pneumatic)mounting-style: no screwsPowerFlyback?: Noprimary_trigger: Hallsecondary_trigger: Hall
Engine specification
* Nissan CA18DET, 1.8 litre 4 cyl * Custom exhaust manifold * Custom intake manifold * H-beam rods and Wiseco pistons * Upgraded oil cooling system * Turbo is Holset HX35, 54/60 in/out * 440 cc low-Z injectors * Stock COP ignition system * Uses 24-1 trigger wheel as described here : VehicleFitment/Nissan
We have our first CA18DET running on the 24+1 trigger disk, with very goode results:
The owner reported back from his first track test that the engine was strong and responsive throughout the rev range.
We have used the standard wiring loom, COPs etc via the use of a harness adaptor:
The motor should be fine as long as it's in good condition right now.PapaBurgundy wrote:I was wondering what kind of manifolds people use or if they just fab there own? Since my turbo is a t3 flange internally wastegated one I was planning on using the topmount ssauto manifold and cutting off the wastegate flange.The rest of my plan was to retune my mines ecu for a z32 maf and dsm 450's and run no more than 12-13 psi. Any reason that couldnt work on stock internals and the normal bolt ons? (intake,exhaust,fmic etc.)
Yea, I liked the flex on the outlet, LMAO!BQ.05.TD wrote:thats could quite be the worst external gate set up i have ever seen. wow
Ouch! I just paid close attention and I agree, but again, to each his own.BQ.05.TD wrote:thats could quite be the worst external gate set up i have ever seen. wow
