dash wrote:more advanced? ok... call it what u want, but the results ain't.
What results? The ones in your head?Coil on plug IS more advanced than a coil pack + plug wire. There really isn't any denying that.
dash wrote:downgrading? can't be.... if the performace isn't diminished.
And you know this HOW? YES, there are cars making A LOT of power on standard coils, that does NOT mean they are better, it means they are SUFFICIENT for making that much power.
dash wrote:more efficient? you'll die a wrinkled ol' man trying to drum up a device to measure that. You'll see the tooth fairy & easter bunny 1st.
Ever heard of the term RESISTANCE? Look it up.
Incase you dont understand, there is resistance AND voltage drop in a plug wire, I'm not saying it is HUGE, I am saying that it exists.
Incase you dont understand, a C.O.P Coil is basically a standard coil, which sits DIRECTLY on top of the spark plug, therefore has SIGNIFICANTLY less resistance/voltage drop than a standard coil with a sparkplug wire.
dash wrote:Just remember that LOTS of cars have reached the pinnacle of street performance, equipped with distributors or coil packs - at a level of driveability, power & efficiency none of us will probably ever achieve.
It is true that there are a lot of cars making a lot of power with distributors and standard coil packs, this does not mean that distributors and coil packs are more efficient than coil on plug. You have to get it in your head, that coil on plug is an ADVANCEMENT in technology, it IS more efficient that a distributor or standard coilpack. Just because a certan motor makes so much power running standard coilpacks does not mean that it will not benefit by using coil on plug.
dash wrote: More power to you if you feel COP affords you any advantage over these whatsoever - that exists only in your mind.
I do feel they do and no, this does not only exist in my mind, it is a FACT. If you refuse to accept the fact that putting a coil DIRECTLY on the spark plug, rather than placing it 8+ inches away and using a spark plug wire is JUST as efficient, you are truely a MORON and should have taken physics in high school.
dash wrote:For many of us, 'function' is paramount, so "downgrading" is quite acceptable Remember Marks' 440whp street ca18 ? ya... downgraded.
Decreasing the efficiency of your ignition system is hardly a "function" modification, more like "my standalone cannot handle coil on plug" so I will use standard coils rather than purchasing a better standalone system.
Awaiting your ingenious reply.
