we might as well put some nice heatsinks on top of each coilpackthemadscientist wrote:If you go computer fans get the nifty led ones!
science teaches us that air is always moving. i may be wrong here but from what i remember high pressure air moves towards areas of lower pressure... thus the cooler air is looking for 'warmer' air to merge with since it's less dense... but of course, take in the factors of a moving car and the air being forced through the front dam or possibly a hood scoop (like myself), it probably wouldnt be that much of a difference.float_6969 wrote:I'll bet you the hot engine bay air is cooler than the air down in that plug valley. Plus it would be moving hot air, which still cools better than not moving hot air.
Now youre thinking! =Dfloat_6969 wrote:Wait, I've got it! We'll fill the valley full of vegetable oil. Then we'll hook up a pump and a radiator for the oil. Less amp draw than the Peltier cooler for sure.
It'll kinda make changing the plugs a pain though....
Yeah I know more of a jokethemadscientist wrote:rainy days would worry me as much as having no hood.
That's what I did on my stock cover, it looks good and still seems to allow a lot of air to reach the coils. I'll post pictures when I get home.missionsix43 wrote:need to stick a cover in a mill and cut out the plastic between the ridges, that would still look good, cover the packs, and allow air to flow out.
Re-he-he-heally! Got any pictures of this my friend? Interesting exchange. Is it direct or are you using a standalone or something besides the oem computer?dash wrote:or get rid of the COP like many have, converted to bosch or GM coils with plug wires... and live happily ever after
Good idea, get rid of your cam sensor next and use a distributor.dash wrote:or get rid of the COP like many have, converted to bosch or GM coils with plug wires... and live happily ever after
What GM motor did you source coils from? Just a 3800?dash wrote:Missionso you reckon experienced RB/CA folks came up with this alternative so they can work their way back to a distributor ? Tell us your 'better idea' then.
You see our COP offering any advantage over 450hp miata 1.8s, 500hp toyota 1.6s or 650 ft-lb mitsu 4s... all using stock coil packs ?
SDS gets rid of COP & the CAS... ask them if they miss it. Or have you not seen a sds/ca18 monster. Those are GM coils btw.
600hp honda 1.8s rev past 8500rpm. distributor look fine to me.
coilpacks can be more reliable, far cheaper to replace and facilitate 'quick' plug reads when tuning.
