t^2 »
https://forums.nicoclub.com/t-2-u2721.html
Sun Dec 22, 2002 8:46 pm
I suggest you build your own box if your are going witha sealed enclosure. Its not that difficult, just several calculations and your on your way to a new box. Find out the right airspace the woofer needs and built it off that. Just use 3/4 MDF or anything thicker. DO NOT use plywood. A piece of MDF board cost around $17 at Home depot. Get some wood glue or Liquid nails, caulk, nails, buy some terminals, wires and thats it. Buyin a Prefab box will cost you alot and you dont even know if it will fit you sub perfectly, unless you get the place to build it to your specified dimensions. Building your own will be safer, unless you dont have the time or necessary tools, then I would go with a prefab or custom box.
