w1ngzer0 wrote:they must have updated their website becuase the 89-94 wasn't there before.
89-94 HYPER-FLEX SYSTEM Complete Master Bushing Set Includes: Front strut rod bushings, front control arm bushings, rack & pinion bushings, 24mm & 25mm front sway bar and end link bushings, rear subframe inserts, rear suspension arm bushings, and rear sway bar end link bushings.
So this hyperflex thing is what your using?
1995-98 HYPER-FLEX SYSTEM Complete Master Bushing Set- w/27mm front & 16mm rear sway bar bushings Includes: Front control arm bushings, front strut rod bushings, front and rear sway bar bushings, tie rod end boots
The s13 has more bushings then the s14. Anyone notice that?? My question was what bushings are a must and want bushings could i not install if time was tight??
