gwoods wrote:The front pads still have a ton of life left in them?? The rear pads got very hot at the last track days, hot enought to melt the high temp red paint off them. I think this is why they are wearing so fast.
The primary component of pad wear is simply how much use its seeing in relation to the amount of pad material present. Assuming the same pad material, the front brakes on any car is going to see more/heavier use. However, the rear pads on most vehicles are smaller than on the front. If the rear pads are however getting as hot as you say, it may be a sign that you have too much rear brake bias for your use/driving style/available traction.
gwoods wrote:Here come the questions...
1# Should I turn the rotors?
I'm leaning towards NO, I'll do the same brand pads and most likely the same part # so the bedding in should be quick (EBC's web site says 1000 miles!)
Depends really. Rotor condition is the biggest reason to consider whether or not you need to turn the rotor. If its glazed or heavily grooved, then you may want to turn them. If its still pretty smooth and still has a good transfer layer on them, then you're probably fine assuming you stick with the same pad material. If you decide to try a different pad though, you'll want to turn the rotors so you can bed the pads in correctly.
gwoods wrote:Also the rotors are drilled and I'm worried about them cracking if they are turned as of now I have ZERO cracks in the rotors that can be seen with the naked eye
A good set of drilled rotors will handle light turning just fine. These are rotors with radiused edges around the holes which eliminates the sharp edges where cracks generally like to form. I've had little problems having turned such a rotor and running them at a track.
gwoods wrote:#2 Pads
I ran EBC redstuff on the rear, these are street pads but supposed to be better then stock but not rated for racing..... as mentioned they did get very hot at the last track event.... hot enought to melt the zinc plating off the rotors and burn the high temp paint off the pads.
Seeing as how this car is also your daily, you might not consider stepping up to a racier pad unless there is good reason to. If you weren't experiencing fade in the rear then I'd stick to the milder pad to make sure stopping remaind good on the street.
zozoka1212 wrote:If your rotor is not smooth your brake won't function 100%. Usually it does not need to machine off too much. I would resurface it lightly.
I'd be more concerned with the pad to rotor interface than whether or not it is smooth. If there are light grooves in the rotor, then it reveale slight increases in surface area. However, this is countered by the direction with which the force of the pad on the rotor is applied. So there is not real gain or loss here. But when starting with a new pad, the peaks will need to wear itself and the pad down such that the pad seats evenly across the rotor. Minor grooves will seat in no time. Heavier grooves would require turning.
gwoods wrote:I think I would feel a brake bias like front dive or rear pull back under moderate braking although my pad life does agree with your thoughts.
You can not feel brake bias in that manner. Your body will only feel the deceleration period. It will not care which end of the car is stopping you. The only ways to detect bias issues are when approaching the limits of braking where you can detect which set of wheels lock up first. At that, you probably won't be able to detect the severity of incorrect bias. And unless you turn off the ABS, you may not be able to easily detect it this way either. If you could theoretically create the same amount of deceleration using your brake pedal, then do the same thing using only your rear parking brake, it would feel the same.
Sentientbydesign wrote:Lots of misinfo going around.
First lets address the rear wear problem.
Assuming that VDC is off 100% of the time, the problem with the rear brakes are that they are undersized. Considering that the G is nearly balanced. Even under severe braking, a decent chunk of the mass still sits in the rear.
A balanced car does not mean a braking system needs to be balanced. In fact, you'ld be hard pressed to find any car that isn't designed to be run primarily backwards to have greater rear brake bias. The key here is weight transfer. As you decelerate any vehicle weight shifts forward. The faster you decelerate, the greater the amount of weight being shifted. For a given amount of traction, there will be an optimal amount of brake bias needed to such that one set of wheels does not lock up before the other. When each tire can be held right at the point of impending lock-up (technically just beyond it), minimum stopping distances will be realized. As grip fromt ires increases, so does the need for more brake bias between the front and rear as the increased grip will allow more weight transfer, effectively putting more of the load on teh front tires as less weight is on the rear.
Here is a more comprehensive article on the topic:
http://www.stoptech.com/tech_i...shtml
Sentientbydesign wrote:The slotted rotors are probably causing some of the premature brake wear. Some are designed to make a new surface on the pads, basically cleaning/cutting them.
Slots and cross-drilling both wipe the pad face. There is slightly increased wear, but given it sounds like he has some kind of pad wiping mechanism on each rotor, I don't think this is what is causing the premature wear.
I'd probably consider what oldandslow mentioned first and consider that a pad with a higher coefficient of friction will be doing more work for a given amount of pressure from the caliper. This is particularly noticable driving around daily where the rear brakes are going to be asked to do a lot more work than elsewhere. From the stoptech article I linked:
Note mountain of rear brake bias between 0.1G to 0.4G. In theory, the ideal brake bias would be such that it varies directly with weight transfer (both lines on the graph would be the same. However, to my knowledge, the odd shape has to do with biasing handling traits of the vehicle towards understeer, particularly during what might be moderately hard braking.
That said, braking is obviously not even from front to rear and is not a linear proportion according to weight transfer or the size of the brakes. Driving style coupled with the actual brake proportioning curve of your car can dictate a lower brake pad life for you while another driver may experience much different results in the same car.
My suggestion is focus on overall performance. Wear is going to occur and trying to tune for even wear will likely result in poor braking performance. Just change pads and rotors as necessary and call it a day.
