zozoka1212 wrote:If you think about it, it does it both way. Radial and lateral. Say you have a perfect circle groove in the rotor. When it is running out on lateral it will crealte a wider and deeper groove.
How? Lateral runout creates additional pressure on the pad as it reaches it's high spot at a direction perpendicular to the face of the rotor. In which case, the pad's contact area would still only be displaced by the radial thermal expansion of the rotor. I think you need to be more specific about the actual mechanism that you claim to be causing this.
zozoka1212 wrote:Now if that rotor heats up the groove is actually out of the original position and creates even deeper and wider groove. Also puts stress on the pistons. Deeper the groove more of the stress you putting on the pistons.
How does a deeper concentric groove put more stress (perhaps pressure is more accurate) on a piston? Lets assume a case where no lateral runout exists. A deeper groove will not provide any more force on the caliper pistons as the total force applied by the piston remains the same and there sill be no additional force trying to push the piston back into the caliper. Lateral runout can cause this effect when its going from a low to high spot. Unless your definition of a a groove is a whole lot different than what I am thinking, I can't see how this is possible...
