Bump Stop Question
high flya
Car: 1993 S13 240SX SE Hatchback (Project)
2002 E46 M3 Coupe (Depleting my $$$)
2015 YZF-R3
2011 BL Mazda3 GX Wagon (Beater 3)
I'm currently installing Tein S-techs on my S13, should I cut the stock bump stops down a bit to give the shocks more travel? If so, how much is recommended?
dwnshfter
Car: 91 240 rb20
personally i would cut them out all together.....
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
dwnshfter wrote:personally i would cut them out all together.....
You must enjoy the bouncy bouncy of blown dampers. Where did you learn to build suspension, Honda fanboi school of suspension tuning?
high flya wrote:I'm currently installing Tein S-techs on my S13, should I cut the stock bump stops down a bit to give the shocks more travel? If so, how much is recommended?
Bump stops are designed into a vehicles suspension for a reason. Ive never installed S techs personally, but I would think that a small trim of the bump stops should give you plenty of travel. What do you plan to run for dampers? If you are reusing stock dampers I would suggest not cutting the stops at all, as they will be required to deal with the extra spring load.
high flya
2015 YZF-R3
Nothing fancy, just GR-2s. I erred on the side of caution and trimmed about a 1/4 off of the bump stops.
