I have been messing around with the idea of turbocharging my s14 for quite awhile now. I have come to the conclusion that KA-T is the most cost efficient route. If I am going to do this I will be on an extreme Budget (Broke college student). Which isn't a totally bad thing, since I only want around 180rwhp. Nothing outlandish, since this is my daily driver. After researching on how turbos work, what is needed, and everything that goes along with turbo charging I have come up with a budget setup.
EXAMPLES OF WHAT KIND OF PARTS ARE OUT THERE. I haven't bought anything, this is just some of the items and prices I have found after brief searching. Better deals on better quality parts could be found if you are lucky.
SSA Manifold:
http://cgi.ebay.com/ebaymotors...QrdZ1
I have always heard that SSA is worthless, but for my plans it should do just fine. I have seen quite a few low boost KA-Ts using it, and its working as intended.
T25 Turbo:
zerothread?id=147790
Stock SR turbo. Quick spool up, plenty of power for my plans, easy to find, cheap.
Blowoff valve:
http://cgi.ebay.com/ebaymotors...ZWDVW
I read that a stock mitsubishi bov works well with a KA-T. I could be wrong though, if you have a better suggestion for a low budget bov, let me know.
FMU:
There is alot of debate about using a FMU as fuel management. The majority of people will say to use a safc and stock SR injectors. A FMU will work just fine for this setup, there won't be any tuning, and the A/F ratios will run rich with a 8:1.
Oil Lines:
http://www.jgstools.com/turbo/ka24et.html
Complete oiline setup from JGS for the KA24DE using a T25 turbo. "Basically everything you need to plumb in oil to and from most T25 and T28 turbosIncludes TA004-GT, TA044, and a TA046 bung*"
Turbo Elbow/Downpipe:
I'm not too sure about using the SR20 DP. The JGS turbo starter kit uses it. It will bolt to the stock cat, but I'm not sure about the dp to turbo connection. Will the stock turbo elbow fit? Or should a should a stock elbow be used and a dp custom made? Suggestions?
Intake piping:Just a pipe from turbo outlet to throttlebody, no intercooler. Before I get yelled at for even suggesting a non-intercooled setup let me explain. Many sources have stated that intercooling under 8psi isn't needed. Now, take a look at the stock z31 300zx. It is turbocharged as we all know, and if I remember correctly it is set at 6.7psi stock. The z31 has no intercooler, just a pipe from turbo to TB. I have concluded that for the 4-5psi an intercooler won't be necessary.
I believe that covers everything, and as you can see it would be an extremely inexpensive setup. I know the quality of the products is relatively low, I won't be pushing them very hard. If I left something or got my information wrong, please feel free to correct me.
