Compare stock rod length of a S2000 and a stock rod length of the KA.H.D.HUMPERDINK wrote:I find it hard to believe that our rpms would be limited to 5,000 when there is a 2.7 liter stroker kit for s2000's which the company that built it still spins the motor over 9,000rpms. And if thats not enough there is someone that builds a 3.0 liter stroker kit for 4 cyl. volvo's. So I think that until someone buys a kit and runs it the debate about piston speed and rpm limit should just be set aside.
SeanC wrote:why is everyone so scared of pistons speed? if you have strong internals and the cams/intake/exhaust manifold to make power it will be fine.
stock piston speed at 7000 rpm is about 4409 feet per minutewith the stroker kit at 7000 it only raises it to 4684 feet per minute
most factory forged cranks can handle 4600 feet per minutethats nothing compared to formula one at 7500 feet per minute or more.
Modified by SeanC at 5:54 PM 6/7/2007
Carl H wrote:i would be more worried about a piston flying thru the head than the crank.the point here is the more stress added to a system be it power or revs OR both that it doesnt matter how well built it is it still is subject to potential damage.compaing a s2k stroker to the ka stroker is apples to oranges, the s2k i s still a short stroke motor compared to the ka.if you want torque that badly just toss a 350 in the car and be done with it.
haha a big piece of **** eh? i just finished building one of those that currently holds the highest horsepower record. just a hair shy of 400 w tq that will be easy to break with methanol?WDRacing wrote:Mitsu went with a big cube 4 banger in the Conquest...big ole POS. 4 bangers can only be so big. WD
I think this is gonna work great..it's going to be very interesting seeing the output on this kit!ace0073 wrote:Im with you. I tend to believe that with all the hoopla about it being stupid, dumb, over-stroked, etc..... Brian Crower has been around for a long time and would not put R&D into a product that is pointless. Everyone has their own reservations for whatever reason but for me it boils down to this; you can talk all day about what you have, how many pounds you are boostin, how big the ports are on your head, how you spin tires through all gears and put out 8000 hp to the wheels but when you get to the starting line, its put up or shut up. So if I can stroke my KA and its dumb, but I am crossing the 1/8th or 1/4 mile in front of you........I'd love to be the dummy with the stroked KA. Theory is theory but performance is also performance. All this being typed....we will see how it performs quite soon. I called BC and the first kits will be released at the end of next month. They are only releasing 10 kits in the first run, then a few months later another 10 or so will be released. Im sure once this happens, there will be all kinds of feedback to go on. Is it dumb or not dumb...we will see.
