Brembo, Stockers or just turn the old ones?
hannibal
Car: Red Line to Glenmont
NOPIonline.com has the 97-01 Brembo rotors for $26 each...
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
That seems like a pretty good deal. Not sure I want to start to replace the entire braking system, 4 caliper sounds nice but mine were completely replaced at 42k so they have only 40 on them......so many choices
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Remember you can sell your 97 Q brakes for at least $200 to some 240 owners.
BadQ45t
Good call, I will be down in LA this week and my mechanic and I are going to figure out a game plan
xmateo
Car: 04 G35 Sedan
Falkdesigns wrote:Drilled / slotted with stock pads should show no increase in stopping distance whatsoever. The only area that may improve is fade as the slotted / drilled rotors have better cooling, out-gassing and pad cleaning ability.
The largest improvement in a brake system is from pads, not rotors and high heat fluid such as Motul RBF600 (600 degree boiling temp.).
Found out yesterday my mechanic can get me Brembo blanks for 33 bucks each! That's awesome!!!! Cheaper than Tire Rack and no shipping. I'm going to use the new Wagner ceramic pads he's recommending, the plates are pre-bonded to the pads, and he has had no returns with these pads. I'll flush the brakes with Dot 5 Valvoline, I don't really see a need to go with Motul in this car. I'm draining the Redline oil that's been in since Feb (changed Amsoil filter half way through) and going back to Amsoil, and I'm going to flush the PS system this Saturday.
How did those ceramics work for you? I tried them on my J but felt they had a higher stopping distance. I am considering standard OEM for my 99 Q.
