Breaking up on high boost???
SR20S13
Car: 1993 Nissan 240sx - SR20 INSIDE....
Well i just installed my hallman boost controller tonight and when i took it for a test run right when i get on it and it hits 12 or 10 psi it pops and then it goes...
i checked the plugs they were all fine. do u guys think it could be a bad coil pack???
thanks!
mistamacadamian
Car: s13
well we wouldnt know unless you check to see it buddy it could be a number of things so you have to use your brain, check everything that affects breaking up(gap size on spark plugs, boost leak test, test injectors/coil packs, make sure your boost controller is working properly) it could be a number of things so check to make sure everything is good to go then come back. Theres are alot of helpful threads so if you dk how to do something search an see if you can find the answer ya know make it easier on ya self
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Spark plug gap?
Coil packs(are they cracked?)
Boost leaks?
Low grade fuel?
Are you running an FMIC and high volume fuel pump?
SR20S13
well i checked all my **** out and the gap is good on the plugs like they shuold be....
but i found on the #1 coil he spring inside the coil has fallen out and was on the plug....so im guessing that has gotta be it..
oh and im on a smic too but that never effected it before...
mistamacadamian
Car: s13
thats most likely your problem then. the screw the bolts in my coil pack was stripped and would pop out an **** everything up lol so yea fix that
SR20S13
ok well its deff. not the coilpack b/c i took the coil pack out and tested it with a volt meter and it read perfect and when i turned the boost down to 7 again it runs great...im stumped...u think it could be the SMIC??
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
SR20S13 wrote:ok well its deff. not the coilpack b/c i took the coil pack out and tested it with a volt meter and it read perfect and when i turned the boost down to 7 again it runs great...im stumped...u think it could be the SMIC??
did u find ur problem..??
johnnyballs180
Car: 1990 240sx
when i turned up the boost on my car, it crackled real bad and stopped accelerating for a moment, but if i let up on the gas a tad or just toughed it out, it would catch again.
i put in a sard 265 lp/h with a new fuel filter, and that actually solved the problem 100%. so, my guess, if everything else is fine, not enough fuel to deal with the extra air?
