FarFetched wrote:If you knw that you are going on a trip, then you should have done it some time before the trip. A week or so before!That is what you are paying to have it done at the last minute.I am sorry, I am being rude but this is true!Seriously, never procrastinate things you can do on time!Cheers!P.S IMHO those pin-heads should compensate you for all your troubles. Servicing a car for 8 hrs call for opening of a can of whoopa$$!
I think you missed my whole post here, I never let anyone touch ANY of my cars. I bought this car last year overheated and slowly rebuilt it back to OEM. I am working on this car all by myself, so if anything goes on it- its my fault. I can't blame myself for having the rod bearing issue now- I didn't touch the lower end of the motor when I did head gaskets on it. Plus I never had any warnings of the bearings going till they went. I was going to go ona trip with the car, but since it will be just getting broken in- I don't wanna risk any problems down the highway.
To all the other replies...I checked my block before I put it back togheter, it checked out perfect with a straight edge, and cylinder bores where perfectly aligned. The block and heads are in good shape. I've seen some SEVERELY overheated engines in my life- like a Integra which someone left runing for 24 hours in our parking lot and blew the radiator durring some time. Car actually stopped runing, after doing a head gasket and head straightnening the car is still roaming around.
It takes TREMENDEOUS temperatures to warp the crankshaft, and if that is not warped and my block is not warped, what is wrong with my VH ?
Its getting new rod bearings and that is it. Unless the crank is scored- I will NOT buy a used engine with unknown maintenance records. I actually have a stack of maintenance recepits in the glove box from the previous owner.
If the engine spins another rod bearing year or 2 from now, I will just rebuild it again. For now I need to get this car going as my Maxima is in the body shop and I have nothing else to drive. My Q is a 1000 dollar car pretty much, no matter how I look at it, 1000 dollar car or xxxx+ dollars less in my pocket every week because I can't drive to work is bad. Its just a hoppty and that is IT.
I've considered just trading it in at Nissan on a 03 M45 even, but I do not do car payments.
