brakes...
jeff420
Car: too many to fathom
if you have inspected the whole brake system and have no leaks, then replace the master cylinder.
as far as the clutch pedal, did it go out ezactly when the brakes did or did you let the car sit for a bit and the clutch went straight to the floor? my 240 used to loose pedal feel if i let it set for a day or two and it ended up being the stock dampener system. i removed it and bled the clutch by myself.(yeah that was fun usin a stick to hold the clutch pedal down while i bled the system) my dad told me an easier way though using a jar with fluid in it and a hose running from the bleeder screw into the jar.
S13Joe
Car: 92 Coupe
even though i think this is a Z32 MC its pretty much the same thing. i noticed this was loose on my MC, could this make air get in the system? all the other ones are tight besides this one.
UndftdSole
Car: 90' 240sx RB25DET, 07 Subaru WRX
did u try replacing ur MC already?
S13Joe
Car: 92 Coupe
not yet, im going to check out everything today then possibly go get one tomorrow. how much do u think the junk yard would charge for one?
94_240sx
Car: 94_240SX
sbird1 wrote:1. Re-bleed the brakes starting with the caliper furthest away (passenger side rear)
The caliper furthest away is driver's side rear on 240, not passenger side.
94_240sx
Car: 94_240SX
DirtyGhettoKids wrote:i noticed this was loose on my MC, could this make air get in the system? all the other ones are tight besides this one.
Yes, it's possible. Everything should be tight with no oil/air leaks.
