brakes...
S13Joe
Car: 92 Coupe
having problems with the brakes... replaced the rear rotors and pads and front pads after something happened and my brakes disappeared so there was no pressure on the pedal... so i bled the lines today and all that but theres still no pressure at all unless the car is off... any suggestions? probly a stupid question but w/e. brakes arent my thing.
AZ89two4Tsx
^ Do you have enough fluid in the system? Are you leaking anywhere? Bad MC? Idk, just throwing some ideas out there.
S13Joe
Car: 92 Coupe
fluids fine, no leaks. mc?
Ilvemynissan
Car: 240sx s13
MC= Master Cylinder
S13Joe
Car: 92 Coupe
how would i check if i had a bad mc?
sbird1
Car: 2006 BMW 325i
Look for rust or paint damage on your brake booster under the MC. That's always a good indication. I'd say bad MC as well. Anybody know symptoms of a bad booster?
S13Joe
Car: 92 Coupe
i was thinking the booster, me and 2 of my friends were tryin to figure this out today... any more suggestions?
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
i think, if you press on the brake pedal firmly it will stop at a certain point then it will slowly go down even further then that means your Master Cylinder is on its way out
S13Joe
Car: 92 Coupe
i can push my brake pedal all the way to the floor and it will do almost nothing
jeff420
Car: too many to fathom
if your booster was going out the pedal should get stiff and you would have a vacum leak.
S13Joe
Car: 92 Coupe
so then i just have a bad mc?
jeff420
if you have bled every corner starting with the right rear (farthest from mc) and gotten all the air out of the lines i would think so. did you lose pedal feel before you changed the brakes?
im_looking_for_a_240sx
!240RB! wrote:i think, if you press on the brake pedal firmly it will stop at a certain point then it will slowly go down even further then that means your Master Cylinder is on its way out
danggggg.......looks like i need to find a new master cylinder. i got rust and paint damage...and i think a leak too.
S13Joe
Car: 92 Coupe
yeah i lost all pressure before i did the brakes, one of the front pads actually fell out lol. neeeeeeeeed this fixxxxxxxxxed........
S13Joe
Car: 92 Coupe
help? anyone?
S13Joe
Car: 92 Coupe
one more thing... my clutch also lost pressure...
helppppppp
240RB1
92 Nissan 300ZX Z32
If you lost your clutch pedal the go straight to your slave cylinder bleed it or replace it since its only 15 for a new one or it could be the clutch master cylinder but hope not
hey im_looking_for_a_240sx update your sig dont you now have meshies i think i saw them on KCDA
S13Joe
Car: 92 Coupe
you think that should fix everything?
240RB1
92 Nissan 300ZX Z32
First check the level in the master cylinder for the clutch if its empty fill it up and go to the slave cylinder. its on the transmission held by two bolts, bleed it and see if it gets better. if its all wet its probably bad because all the fluid leaked allover itself so replace the slave and bleed it you should be set. as for the brakes idk what to tell you i havent read all the posts thoroughly sorry il read them then tell you sumptin K
sbird1
Car: 2006 BMW 325i
Here's what you need to do:
1. Re-bleed the brakes starting with the caliper furthest away (passenger side rear)
2. If that doesn't fix it, make sure you have no leaks
3. No leaks, THEN spend the money and buy the new MC. If that doesn't fix it (unlikely) then report back...
4. Turn attention to the clutch. Make sure there are no leaks in the system there. 240's have problems with leaky clutch lines...
5. Remove the slave (really easy. 2 bolts off the transmission). Have someone look at/feel the slave as you pump the clutch. No leaks, no movement from slave = new slave.
6. If that doesn't work, buy a new clutch MC.
240RB1
92 Nissan 300ZX Z32
hey man you say you lost your brakes before you changed them what were you doin? did you hit something? check for a cracked line that might be the problem- checkin for a cracked line i guess youd look allover the line and see if its wet anywhere the place thats wet theres your problem. you probably just nneed to bleed all the air out idk its hard to diagnose a problem shat load of miles away whatever it is hope you find your problem it sucks when my car breaks down on me (knocks on wood)
S13Joe
Car: 92 Coupe
its kinda weird because as soon as my brakes went, my clutch lost pressure too...
S13Joe
Car: 92 Coupe
i checked all the lines. no leaks and i didnt hit anything, the story goes is my brakes were making a really ****ty noise for about 2 weeks. kinda like a airplane landing lol i know it sounds stupid. but anyways as i approached a stop sign not too long ago the noise came as usual and then SNAP, no brakes. today i bled all lines besides the rear left (drivers side) the bolt actually snapped while i was trying to unscrew it. so i left that one, its still in there though lol. so i bled them all, still no luck, checked for any leaks or anything, nope. so im lost.
!240RB! wrote:hey im_looking_for_a_240sx update your sig dont you now have meshies i think i saw them on KCDA
fixed and updated, and my thread updated also
240RB1
92 Nissan 300ZX Z32
so you ran your pads till there was nuttin left? if so then it probably is you master cylinder that went out because it was pushing fluid beyond its safe limit and it damaged the piston or seal inside, another possibility could be that the bleeder screw you broke off its still open so its taking in air and not lettin the brake system evacuate itself of all the air
moulton712
Car: coupe, hatch, both s13s
fyi i know most of you know this but your breaks and your clutch are two different systems. so you have two different problems.
meaning one system doesn't affect the other.
S13Joe
Car: 92 Coupe
its not still open, i checked. i felt like such a idiot (<3 rust). so have we reached the final verdict? replace the master cylinder?
240RB1
92 Nissan 300ZX Z32
if you did run your pads down to the bare metal their is a possibility you did screw up your MC now im not sayin thats the final verdict but im sayin its a great possibility.wait an see what other people say, id go ahead and replace it but its your money do it if you want haha Good Luck
S13Joe
Car: 92 Coupe
well the weird thing is that the rear rotors and pads were worn down to ****, i can put up pics if u want lol its actually kinda funny. but the fronts werent that bad. btw i appreciate the help you've given me so far. but i still wanna know wut i should do lol. JUST about the brakes though i can handle the clutch
S13Joe
Car: 92 Coupe
bump
need help
