The rotors won't turn unless I release the pressure at the bleeder screw. All four. I thought I mentioned that, I guess not!elwesso wrote:So are you sure its the calipers that are locked up?
I did lube the pins, maybe with the wrong stuff tho now that I checked it out...elwesso wrote:Did you lube the sliding pins properly and all that fun stuff? Usually when they lock up like that its because the caliper gets lodged somehow on the pins, maybe one is bent?
If it only happens with engine on, then:Dattebayo wrote:I really don't think it's either the MC or the hoses because what I wrote up there... ^
Dattebayo wrote:Booster and MC were checked, not the problem.
I don't see what valve would cause the problem in the ABS, the FSM shows a clear by-pass for when the system is not activated.
ABS block is a generic term for all the actuators, solenoids, and valves that make up the main part of the ABS system. They are usually all grouped together.Dattebayo wrote:I just now disconnected the 20 and 30 amp ABS motor and cont. fuses in the engine compartment, I disconnected the motor relay and actuator relay as well. Anything else I should disconnect?
The brakes are still holding, but it's only been 10 minutes since I did all that. Where is this "ABS BLOCK" you speak of?
3 Seconds sounds about right for the rear, but Im surprised the front will spin at all. With all the axle and trans stuff, front wheels usually only make it a turn or two unless you really get them going.Dattebayo wrote:Okay, the rear e-brake cables seem to be hanging up independently of each other. If I apply the brake it does not make it lock up anymore when the e-brake is disconnected.
But the right rear one (which I replaced) is dragging slightly on the rotor. So that makes it the right rear and the front left that are hanging up.
I read in the FSM that the actuator controls things in pairs of opposite corners, so I wonder...
How long should the wheel roll when I spin it? I get about 3 seconds of spin on the rear left, same on the front right...
truckboy wrote:I am assuming your symptoms are somewhat off. If the car is carbureted then I suspect a carburetor float problem. Also it is possible that your fuel pump pickup may have a problem. These are, of course, just best guesses. I will be interested in others answers.
I do believe you are having a fuel delivery problem.
What happens when you drive down a steep street? Do some experimenting going up and down a steep grade.
When your engine stops the brakes no longer have power assist. Some brakes are very difficult to apply without assist.
Same thing I was wondering. He's been spouting random in all kinds of threads today.FlatBlackIan wrote:truckboy wrote:I am assuming your symptoms are somewhat off. If the car is carbureted then I suspect a carburetor float problem. Also it is possible that your fuel pump pickup may have a problem. These are, of course, just best guesses. I will be interested in others answers.
lol, wut?
