BRAKES!!! BIGGER=Better
GorillaClub
Car: Racing...
hey, trying to finish the suspension on my 91 240sx. I decided to keep the car 4 lug for the long run and now all I need is brakes searching high and low through the post all i find is the z32 upgrade, with money not being much of a problem what brake kits are some people running and how do you like them. I found a kit 12.2" all around all hardware and everything seem good to me when comparing it to brembos, rotora's, and fast brakes.
stillmatic
Actually, more mass = better.
Nismo_Freak
Car: 89 Nissan 240SX
With the Z brakes you can easily lock-up the front tires... so in all fairness unless you are doing stops from 150+ mph or repeated high speed stopping, like on a roadcourse, there is no reason to get larger brakes than the Z brakes other than to impress your friends.
Nismo_Freak
stillmatic wrote:Actually, more mass = better.
More swept area = better
Exar-Kun
Car: 2005 350Z
uhm more hp=better?
dude, if you can lock up your brakes, you have all the stopping power you need. If you are racing and experience brake fade/head spotting, consider upgrading the brakes, until then, dont waste your money, you wont gain any better braking.
in fact, someone tested the Z32 verus stock brakes, it actually took a longer distance to stop WITH the Z32 brakes from 60...I believe it was about the same from 100mph.
just a thought.-chet
Snarlynx
chet... was it an apples to apples comparo?
I mean, same pads, the "correct" (I know the definitive size is debated but still...) MC for the Z brakes, same tires et al.?
I'm not doubting the results just when you say "someone" it makes me think it was a rather informal test is all.
Nismo_Freak
Even with the incorrect MC it's just going to allow for more pedal travel before lock-up... so the car should stop faster actually.
The problem is the tires, not the brakes... most people run on pretty crappy tires and skinny ones at that.
You have X amount of braking force and Y amount of tire traction.
Doubling X just gives you more force but Y remains constant.
When I was running my 215/45/16 Falken Azenis I could hardly lock up the front brakes in a non-abrupt pedal depression. However when I converted to 5-lug and got the cheaper Falken 512s (with the wheels) I had problems applying full brake force on entry.
This was just using Axxis Metal Masters on stock 4-lug brakes... the 5-lug conversion actually brought me back to OEM crap pads which helps to further my statement.
Exar-Kun
Car: 2005 350Z
yep in 99% of cases, tire grip is going to limit the brakes ability to stop the car, not the diameter or clamping force of the brake system itself.-chet
Nismo_Freak
So if I have uranium rotors I'm all good right? :D
I understand what your saying, just poking fun.
Nismo_Freak
Exar-Kun wrote:in fact, someone tested the Z32 verus stock brakes, it actually took a longer distance to stop WITH the Z32 brakes from 60...I believe it was about the same from 100mph.
I recall it stopping a whole 2 ft. shorter with the Z32 brakes.
Either way it doesn't warrant a brake upgrade... it warrants a tire upgrade lol.
IB 335/25/19s all around :D
lessthanjakejohn
read teh new GRM article anyone?
Nismo_Freak
Haven't gotten the new issue... worth it?
Twintip_yeti
Correct me if im wrong but one of the reasons why you would upgrade to the z32 brakes is because they wont fade as soon as the stockers?:confused: im jw
Exar-Kun
Car: 2005 350Z
its got better ability to dissipate heat, because of the larger rotor mass, thats the reason to upgrade, not because it "stops me faster"...
some people say its the same thing, but it is not.-chet
Snarlynx
Plus they look like look like a bajillion times better espesially cross drilled and sloted (lost mass be damned). Plus if you get skyline ones off of a clip it's JDM tyte. :pface
Exar-Kun
Car: 2005 350Z
I never judged a car by its brakes....:p
but yes, a worthwile upgrade for those of us track junkies or really, really spirited drivers...hah.-chet
Snarlynx
I've seen stock brakes behind 19's on a 240 once. It wasn't pretty. :eek:
I know the primary reason is to dissipate heat and I was half-joking when I said it was JDM tyte, you've got to admit big brakes look good behind wheels. ;)
MarkEmark
Car: fully-built '95 240sx KA-T
bigger brakes = more unsprung weight (and rotational at that).
As usual, I agree with chet. You don't need huge brakes for a light car. I seem to have plenty of braking with my brakes, and I just have upgraded cross drilled rotors + kvr carbon kevlar pads on all 4 corners; never experienced any kind of brake fade.
Plus, z32 brakes with my 15" Work 3-piece wheels are a non-option; they JUST clear my stock brakes (they actually make my stock brakes look really big-it's the illusion created from the thick lip and small diameter of the actual spokes).
Snarlynx
Can I see a pic of those wheels? I'm a fan of work wheels. espesially 3 piece with a (hopefully) polished lip.
And if they are black with a polished lip... all the better.
MarkEmark
The pic doesn't do justice to the wheels--they're reaaal shiny :) I like them; they remind me of Ferrari F40 wheels. Dunlop sp sport 8000 225's in the rear, yokohoma avs es100 205's up front.
http://24.59.109.135/pichost/pic//120-2055_IMG.JPG
http://24.59.109.135/pichost/pic//120-2056_IMG.JPG
http://www.eniety.com/pichost/pic/120-2041_IMG.JPG
Also, why is your font always bold?!?
Exar-Kun
Car: 2005 350Z
he's cool like that :p
nice wheels man, they do look a bit like F40 wheels(but much smaller..hehe)
how much do they weigh? any idea?-chet
MarkEmark
Chet--They weigh EXACTLY 14 pounds...not a hair over. So I'll quote 13.9 :)
Not as light as I'd want, but they look awesome and are obviously extremely strong/stiff being three piece.
Yes, not as big as an F40. But we can pretend :ylsuper
Exar-Kun
Car: 2005 350Z
now to just get a twin turbo 2.8 v-10 with 485 hp in my ca.r...
donations anyone??!?!
hehe, 14lbs isnt too bad at all. anythung under 1lb per 1" diameter is good.-chet
MarkEmark
Exar-Kun wrote:now to just get a twin turbo 2.8 v-10 with 485 hp in my ca.r...
Wasn't there someone on the Fresh Alloy forums who was going to swap a 308gt ferrari 3.0 v8 into a 240?!?
I gotta stop post-whoring. It's addictive :(
Snarlynx
Damn those wheels look old shcool. Why did you get 15's BTW?
As for the bold, it's a habit I started at IGN.com that has carried over to every other forum I visit.
Q45tech
Just remember a single stop from 60 mph won't heat the stock rotors up by more than 100-150F even in summer and the pads don't begin to lose friction [increased pedal effort] until 500-600F.
MarkEmark
They may look old school, but they sure as hell have more character than 95% of the wheels you see on imports today.
I got 15's to save weight, period. I had 17's with 235's on it and hated how bloody sluggish it made my car feel (accelerate, brake, steer, handle, etc). Wheels make a damn big difference when it comes to the overall feel of the car. Even with 9 psi, the 17" wheels were just too heavy for my liking.
Marc
Snarlynx
I like old school. :)
The 15's however... I like performance and give it the nod 9 times out of 10 but I'd rather just get 17 inch forged shoes as a comprimize. ;)
MarkEmark
Yes, in a perfect world with no financial limitations I would have opted for 17" forged wheels, such as the ssr competitions or the 5zigen fn-01 r---but I would have payed a lot more for wheels had I done that.
240Stilo
MarkEmark wrote:They may look old school, but they sure as hell have more character than 95% of the wheels you see on imports today.
Marc
And then again...I have 235/45/17 in the rear and my car doesn't feel slow at all.
When it comes to brakes, a good bang for your buck would be to get some q45 rotors and calipers. After the core deposit they came out to $170 ($230 up front). These brakes can be used with the stock lines so the rotors and calipers are all you really need. I decided to go a step further with this upgrade and buy stainless steel brake lines all around.
Now for the performance...VERY good stuff. I use Raybestos ceramic brakes with it and it still stops very well. Very good control and feel to them also. They don't make the pedal mushy or stiff (e.g. upgrading to 300zx MC). I retained the stock feel and only notice the braking power is there when I really get on it. 300zx brakes are said to be a little more difficult to control a gradual stop for everyday driving.
