Brake upgrade which would you choose?
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Im doin a quick brake upgrade to the front only
Options are:Z32 front brakes OR Q45 front brakes
Im leaving the back stock Im not concerned about which cost more or lesswhat would you say is better to do?
lol damnit i thought i posted this in a different section.. OH WELL!
180weaver
Car: 90 240sx
not sure on better, but you should be able to find some for a good deal on ebay. I bought the set of z32 cant remember if they are 26 or 28mm, but the lightweight aluminum ones and am happy with them. You should check out steel braided lines and auto bleeders since you will be working in that area anyways
OM3GA
Did you leave your back stock? and do you have abs or no?
I guess i should throw out there its an s13 without ABS
Pento240sx
Car: 1995 Nissan 240SX SE, 1981 Datsun 210 Deluxe, 1981 Datsun 810 Maxima Deluxe and 1999 Infiniti Q45t.
I would say get the Q45 brakes, they are really easy to install and are plug and play. With the Z32 you will have to get the Z32 brake cylinder. Q45 FTMFW BTW: They are way cheaper than the Z32 Brakes.
180weaver
Car: 90 240sx
i haven't installed the rear ones yet because they require e-brake alteration and until i get the hydraulic e-brake i wont use them. I found a good set on ebay for 50 bucks so thats pretty cheap, and if you look you'll be able to find steel braided lines that make them plug and play, minus the ebrake issue of coursehttp://www.240sxmotoring.com/24z32brcoli.html, but if you search for that as well there are ways to make em work. good luckhttp://www.ultrarev.com/Univer....htmlThis is the kinda setup i wanna go with, i also wanna get the auto transmission brake booster and a larger master cylinder, should be more that enough stopping action
Modified by 180weaver at 2:18 AM 2/24/2009
Taylor008
Car: 240sx Coupe
Pento240sx wrote:With the Z32 you will have to get the Z32 brake cylinder.
No you don't...
ImportBastard
Car: 1989 coupe
z32's I'm running fronts and backs with the stock Master... no problem what so ever....
nissanman04
Car: '90 240SX, '95 Subaru Legacy
What are you using the car for? If you plan on tracking it at all I would recommend the 30mm Z32 calipers since there are many more choices of brake pads than the 26mm Z32 or the Q45 calipers.
Warped161
Car: 90 s13 the never ending project
Q45 upgrade FTW do yourself a favor and get some braided brake lines while your in there.
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
Z32!
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
I would go with the Q45s if you are only doing the fronts.
Not only are they more cost effective, but they will stay closer to the original brake bias. They will also allow a greater choice of wheels.
Initial_R90
Car: 2003 Zo6 Corvette RIP BLOWN up on the dyno
2003 Evo VIII
i had q-45's stoped me on a dime and never had really bad brake fad from high speed stops from 160+ , dunno what pads were on them tho
OM3GA
I use the car for auto x and drift and mountain driving, I would be either getting the 30mm z32 setup and changing the master cyl too or just the q45. If you have the Z32 brakes in the rear can you use a hydraulic Ebrake and have it lock the regular pads up like the stock rear on the 240 does or does it still lock up the little pads in that small drum thing? I hate the drum e brakes thats why i wouldnt do the rears too.
S133P3R
Car: 1989 S13 240sx
J30 brakes work also, bit smaller but almost the same as Q45. Q45/J30 will fit stock wheels as the Z32 will not.with the Z32 brakes its best to upgrade the whole system as your bias will be off with a stock BMC.
i grabbed my J30 rotors/calipers from a junkyard, $50+$10 rebuild kits and a day later... they look better than new. there is a write up in the "tech" section above...
180weaver
Car: 90 240sx
i feel you on the neverending 90 s13 project warped. How did you decide to do your build. Turbo or N/A. lemme know if you hear of where i can convert my lifters from hydraulic to solid or by some divine miracle hear of a fully counterweighted crank.
S133P3R
Car: 1989 S13 240sx
DUDE JEREMIAH WEAVER! its APE! from kihei regency, noah, matt howard days in kihei? u remember me?
AZ89two4Tsx
Q45's are much more cost effective while offering almost the same performance as the z32's. Not to mention the wheel clearance issue with the z32's.
180weaver
Car: 90 240sx
yeah, yeah, where are you at now? You still on Maui. Man those were interesting days. you have a 240 eh, killas. catch ya lata
OM3GA
Interesting and which Noah are you guys referring too? lol anyways back to topic, the only reason i wouldnt do the z32 rears is because i hate the ebrake they use, If using a hydraulic ebrake utilizes the pads to lock the rear instead of the internal drum i would definitely do the rears as well.
180weaver
Car: 90 240sx
yeah it does, i posted a site you can check out in an earlier post. There are more than just that company making them, but they hook into the master cylinder and then run to the some kind of link with the rear brakes and are essentially the equivalent of using the foot pedal to power the rear brakes.
S133P3R
Car: 1989 S13 240sx
OM3GA, where you at in cali? noah robertson, sound familiar?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Im knee deep in Z32 brakes so there's my vote!
S133P3R
Car: 1989 S13 240sx
positron,your write up definitely comes in handy... ill be using it later..
OM3GA
S133P3R wrote:OM3GA, where you at in cali? noah robertson, sound familiar?
Hmm maybe if i saw a pic of him, Im in Norcal but im up and down cali alot haha anyways I think the Noah im thinkin of has a last name that starts with a C not sure though.
positron1
S133P3R wrote:positron,your write up definitely comes in handy... ill be using it later..
If I can help at all just let me know man!
