Brake Pads Worn
Rex wrote:If I understand correctly, you need to trace the wire from the caliper as far back as possible, but the wire (that goes back to the car) is no longer there. You should be able to find that info in the FSM, which I'm pretty sure Wes has committed to memory. He should be able to tell you where it runs to (from the rotor/caliper). This may be a mod most never considered. If you were to pull both the front and rear sensor wires, you could reduce your weight by 8 to 10 ounces. Lighter weight car will go faster :D.
Exactly. I was on the phone thumbing through the books with Wes, and he found some connector box in the dash near the glovebox where it apparently begins.
And unless I win the lottery, decide to retire early and have absolutely nothing to do, I'll choose against going in there. :)
-Jesda
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I tihnk it will be a lot easier than you think..... If you dont mind when you bring your Q up I can try it.. WOrse case you live with the message youve lived with forever!!!
DAEDALUS
Car: 1990 Infiniti Q45
Jesda wrote:The wire in my hand, which I cut off a year ago, goes from the caliper to nowhere. Its the other end that goes to the rest of the Q's electronics that I cant find.
Jesda, what is on the other end of that wire? If it's the pad sensor then I would say yes, it goes to "nowhere". If it's a connector, then you don't really have a problem. One of those 2 "black hoses" in the background of the pic is the wire that carries the pad sensor current. It isn't missing! The sensor connects to the "back" of the caliper. You can see it just fine if you stick your head under the oil drain plug, and I'm guessing if you did you would be looking at the connector end of the wire that you're holding there.
I tried cutting and twisting those together just now, but nothing changed. So apparently that dangling piece of wire just goes to the connector on the caliper attched to the pad sensor and nothing else. When I get proper jack stands I'll look further inside by the oil drain plug.
THANKS!!!!!
DAEDALUS
Make sure both front and rear sensors are closed circuits.
Ahh, good reminder. Is the rear sensor also on the passenger side?Thanks again
-Jesda
DAEDALUS
Yeah same side.
Rex
Car: None
If it's the rear sensor, that's gonna be freakin' hilarious.
That's got BlondeStar written ALL over it :D.
DAEDALUS wrote:Make sure both front and rear sensors are closed circuits.
So... I checked the rears. Twisted the wire together. The pad wear indicator went away. Thank you. :)
http://media.ebaumsworld.com/i...r.mp3
