Method A is the "traditional way" with taking out the no1 coil and jury rigging a spark plugs wire from the plug to the coil, etc.....
Method B is the clamping of the wire, that I discovered!
On a side note, this picture really shows where the connector and wire is that you use for Method B... As far as I can tell there are one of these special wires on both sides of the engine, and its in a similar place on the drivers side and is idential looking.....
Method C is using SST, where you unplug the 2 connectors going into the ignitor packs, hooking it into the little thingy, and clamping the wire on there........
As far as I can tell they are "check connectors" as refrenced...
In fact, I got so interested in tihs I re-read the last pages of the EL section and I cant find ANYWHERE these little mystery connectors... They arent listed in the main harness connectiosn, where it lists EVERY conncetor, its function, and where it goes..... Weird...
