http://www.stoptech.com/tech_i...shtml
About 2/3rds of the page down.
Quote »Hey – you didn't mention DOT 5.1 fluids!
Historically, DOT 5-level performance (specifically boiling points and viscosity) could only be achieved with silicone-based fluids. However, modern compounding has created glycol ether-based fluids which now meet DOT 5 bogeys in these key areas. Consequently, the DOT 5.1 moniker was created to differentiate between these two very different chemistries which both meet DOT 5 performance requirements.
In so many words, DOT 5.1 fluids are simply DOT 4-type fluids which meet DOT 5 performance requirements. Because of this, they typically can be mixed with DOT 3 or DOT 4 fluids without concern. In some circles, they are even referred to as ‘DOT 4 Plus’ or ‘Super DOT 4’ fluids because they are more similar to a conventional DOT 4 fluid by chemistry than they are to a conventional DOT 5 fluid. In fact, DOT 5.1 is essentially comprised of Borate Esters.
While it may not be obvious, the big advantage of the DOT 5.1 fluids is that they contain all of the nifty water-absorbing characteristics of the DOT 3 and DOT 4 fluids while simultaneously providing for very high boiling points and relatively stable viscosity over a wide range of temperatures. The best of all worlds, you could say. The table below sums it up quite nicely. PROPERTY DOT 4 DOT 5 DOT 5.1Dry BP (F)@ 0.0% H2O 446 509 509Wet BP (F)@ 3.7% H2O 311 356 356 [/quote]
