EstoMax wrote:i have ss lines, and i have actually rebled them a few times. I doubt that is the problem. And i realize that my brake balance is off with front/rear. Eventually I want to move the z32 rears, but so far this setup has worked ok at the track.
Isn't there some little fitting i can put inline where i can lower the pressure in one of the brake lines? hehe.
i guess i will be doing another rebleed and testing them.
Marko
A restrictor would only allow you to change flow, and reaction, not pressure.
If you cant fix the problem with bleeding, it is likely that your right side caliper is not working properly, or siezed. If you have ABS, it is also possible that you have air trapped in actuator.
