PoorManQ45 wrote:I know that there have been previous posts on this subject, but I have some new questions.
What brake rotors fit the Q45? Will rotors made for any other Nissan/Infiniti vehicles fit the Q?Z32 TT rotorsWhat calipers fit the Q? Do calipers made for other Nissan vehicles fit the Q?Z32 TT calipers
What are the suspension upgrade options for the Q? I know about the Tokico stuff, but is there anything else? Does anybody make adjustable coilovers or shocks/struts for the Q?I have TT coilovers that will fit the Q. Basically the TT suspension will bolt into the Q. Not sure how suited it would be for a 4,000+lb car though. I have already put solid adjustable tension rods on my Q from my TT. I plan on putting in adjustable front & rear upper control arms from my TT along with an entire rear suspension & diff from a Z32 N/A for the 4.08 gearing & all the solid bushings that were put into my N/A rear suspension. I will post pics when I finish. Hopefully next weekend.
Well, if I were going to change the brake rotors and calipers, I probably wouldn't be using OEM equipment. I mean, what would be the point of that?AZhitman wrote:Lots of rotors have the same bolt pattern, but any upgrade in diameter will require custom brackets. I'd recommend twin turbo Supra rotors for max diameter, or 3000GT rotors, with some 300ZX aluminum calipers or some Skyline calipers... No Nissan (besides Skyline) has larger ones, although the rear 300ZX rotors are vented. Really no need unless you're doing road course / autocross.
Do you have any recommendations? As you've seen before, I don't really know how to choose tires. I can't figure out what the load ratings are.AZhitman wrote:Tires? 255/50/16. Tire Rack is a great source, and that's a PERFECT size for the Q. Extra load rating, nice width, and OEM diameter.
Those 255/50/16s have a load rating of 99. It says it on both the Tire Rack & Discount Tire web site on how to read tire info. Do some research. The Hitman mentioned once that he had Falkens on his 16" rims, but I doupt you can get them for under $90.PoorManQ45 wrote:Do you have any recommendations? As you've seen before, I don't really know how to choose tires. I can't figure out what the load ratings are.
Not to be an a-hole, but why are you even talking about getting 4 piston calipers when you won't even pay retail for plenum hoses. We know your cheap. Your not going to spend more money than what your car is worth to upgrade calipers, big rotors, and the 18 in rims you'll need to fit those rotors. Most likely, your brake upgrade will be cheap pads at Napa and you'll resurface the rotors with a hand sander. And you'll still ***** about the price. I'm sure the rest of you guys would agree with me.PoorManQ45 wrote:I'm talking about using something from Brambo or Baer brakes. Maybe some 4 or 6 piston calipers up front and 2 or 4 piston calipers in back. Those combined with Slooted and/or Drilled rotors would significantly reduce stopping distance, correct? I mean, as long as the tires could provide the grip/traction.
Um... there is something special about them. Having multiple piston calipers allows the pad to be applied to the rotor more evenly. Also, having more pistons can get the same job done with less pressure. And, m the more pistons you have, the larger the brake pads can be. The larger the pads can be, the more friction that can be exerted on the rotors.Q45tech wrote:The rear only does 30% of the braking at most. Don't confuse multiple pistons 2,3,4,,,,6 for anything special.
Do all 255/50/16s have a load rating of 99?louiegz wrote:Those 255/50/16s have a load rating of 99. It says it on both the Tire Rack & Discount Tire web site on how to read tire info. Do some research. The Hitman mentioned once that he had Falkens on his 16" rims, but I doupt you can get them for under $90.
See, you're intupreting my "cheapness" as me being stupid. Am I stupid for trying to do an under-plenum job for under $100? If you think I'm stupid/cheap for doing this, you are sadly mistaken. I think that all of you guys that paid $300+ for RUBBER HOSES are idiots. There is nothing special about OEM ****. And that's what it is, ****. Come on guys. You should think about this stuff. Especially you Q45Tech, you are the smartest guy on this forum. You should realize that there is nothing special about the OEM hoses. So, why have none of you atleast tried what I am doing, before? Is it because you like spending more money than necessary? Well, that's your choice. Learn the value of things before you buy them. And by value, I don't mean what other people pay for something. I mean learn what it actually costs to make something and what other people are selling the same thing for.louiegz wrote:Not to be an a-hole, but why are you even talking about getting 4 piston calipers when you won't even pay retail for plenum hoses. We know your cheap. Your not going to spend more money than what your car is worth to upgrade calipers, big rotors, and the 18 in rims you'll need to fit those rotors.
Avidently, you have not read anything that I posted on other threads about my brakes. I don't have to upgrade/buy new pads or have my rotors resurfaced. I have a lifetime warranty on both of these components. So, they don't cost me any extra. BTW, I also cross-drilled my own rotorslouiegz wrote: Most likely, your brake upgrade will be cheap pads at Napa and you'll resurface the rotors with a hand sander. And you'll still ***** about the price.
Evidently some people look at a wheel and wonder why it doesn't have corners.Q45tech wrote:Why bother reinventing the wheel.
If you didn't notice, I put a roll-eyes thingy at the end of that statement. I did not mean it literally. I only posted that in response to someone saying that I probably resurface my rotors with a hand sander. I have not cross-drilled my own rotors. I have thought about it though. I mean, I have most of the required tools. A wet drill press, steel lathe, and a few micrometers. I would need to have the discs spun and balanced after I did this. But, I know that I should not do this mod myself, because not all discs were meant to have holes in them. Drilling them myself would cause them to crack under stress.rsiwicki wrote:cause I don't know how the hell you have a lifetime warranty on rotors you cross drilled yourself. There is no legal way any company in their right mind would validate a warranty on rotors you cross drilled yourself!!! besides...there are several issues about cross drilling your rotors yourself that can lead to huge safety concern
Explain!1992Q45A wrote:Such poison on this forum
I understand all that. I guess what I'm really looking for is a cheap alternative. If my under-plenum hoses last 10,000 miles, I will be happy with them. Ya know why? Because I can replace them again for ~$35. Also, if my "custon" hoses break, I will try another method.Q45Tech: could you take a look at this hose for me.http://www.lowes.com/lkn?actio...43356Do you think that this type of hose would work for Air/Vacuum lines? To go from OEM parts to this kind of hose, I would have to use a small length of rubber hose, a connector that is barbed on one side and threaded on the other. Do you think this methid would work?Q45tech wrote:My point has always been that $300 hoses are so infintesimal a part of the $9,000 [maintenance and repair] cost [15 cents per mile] to drive a older Q45 for the next 60,000-75,000 miles after the hoses First need replacing.Why bother reinventing the wheel.Almost everything you buy [at oem standards] for replacement has that kind of [+60,000 mile] life if not longer except maybe upper links, brake pads and rotors, of course tires and some suspension rubber bushings and drive belts.
I often wondered why they don't have corners.maxnix wrote:Evidently some people look at a wheel and wonder why it doesn't have corners.
Me being cheap should have nothing to do with how you guys respond to my questions. I asked about a brake upgrade because I was/am wondering if it could be done. Am I ever going to do this upgrade? Maybe, sometime in the future. But right now, I'm still in the wondering/planning phase.louiegz wrote:As usual PMQ, you have totaly missed the point of what I have to say. What I was saying is that if your so cheap, why are you even talking about expensive brake upgrade that you will never do. STOP WASTING PEOPLE"S TIME!
Question. If you guys keep telling other members and myself to go research things before we ask questions, what is the point of us asking questions at all? I mean, if I go find all of the information, there would be no reason to ask you guys any questions. That does not mean that I don't research stuff, because I do. But, there are something that I can not find on the Internet. That is why I ask questions.louiegz wrote:The time you spend on your long posts could be better spent on doing reserch and learning.
Your father is a smart manlouiegz wrote:My father always said that you will never learn talking and not listening.
Early onset of Alzheimer's? Give me a call and I'll help you find it!AZhitman wrote:Someone remind me why I haven't pushed the BAN button (yet again)?
Key word is was a smart man. He passed almost 6 years ago. My Q was his Q that he picked up new, on his birthday. My mom doesn't drive and she gave me the Q. Long live his Q.PoorManQ45 wrote:Your father is a smart man
Um... could you clear that up for me. How was I wrong about what I said about having multi-piston calipers? Do you disagree that having more than one piston per caliper is better than only having one piston per caliper? Do you disagree that a larger brake pad creates more friction than a smaller one when applied to the rotor?AZhitman wrote:You vacillate between calling Dennis "the smartest guy on the forums" and in the next line arguing with himn about brake pistons (and you're - again - wrong).
That was not the meaning that I got from his advise. If I don't argue with you guys, noone will. Everything that you say will be considered true. Even though alot of what you guys say is true, some of what you say is not correct. Would it make you guys happier if people posted questions, one person posted an answer, and that is it? Then, you put me into the equation . You answer a question, even if you are correct, I still must ask why it is that way. There is nothing wrong with this. I like to know why things are. If that pisses you guys off, that's not my fault, you should control your anger better .AZhitman wrote:Take Louie's dad's advice, and quit arguing with people who have 20+ years experience on you.
Because you secretly enjoy laughing at what I have to say.AZhitman wrote:Someone remind me why I haven't pushed the BAN button (yet again)?
Thanks pito.pito11213 wrote:Hitman you didnt hit the ban button because you dont have to. Even though you guys feel like he doesn't want to do stuff to his car...the same info that is put on there can be utilized for everyone. I know I learned plenty. Just because you do not agree with someone's statements or thinking doesn't mean you shouldn't tolerate it.
One problem though. This gives AZ a reason to ban me. I drive my Q really slow. As in less than 1mph. It sits in the drivewaypito11213 wrote:I believe banning should be saved for racist remarks or anything of that caliber...or for people who drive slow.
