BuudWeizErr wrote:A recirculation valve moves compressed air out of the intake tract when the throttle plate is closed and back into the intake, before the turbo, after the MAFS. The pro's are that you won't run rich when you shift, and your car won't backfire. The reason that happens is because with an atmospheric BOV, the MAFS is reading a set amount of air, and the ECU compensates for that amount of air with fuel. With that air not present, the car runs rich, and that is what causes the backfire. A recirc valve doesn't make a cool sound. Thats the only con.
A lot of people have gotten around this problem when using atmospheric BOV's by cutting their cold pipe (IC -> TB) and putting the MAFS in there, in that case, the MAFS is after the BOV.
EDIT: Or you could always switch to a MAP sensor![]()
J-Spec Tuner wrote:Any way, the only problem i have heard of with atmospheric BOVs is that when you stop your car might stumble or just die out. but that problem is a easy fixed as turning your key.
Sintax wrote:now thats an interesting statement...kinda sounds like your under the impressiong that the MAF has an external meter that detects "under the hood pressure". last i checked they did not do that, hence why when you place the MAF after the bov it meters the air that the BOV is letting by and reports that amount to the computer. :thinker
i'd love to be correct if i'm wrong, but this was how we've done it in the past.
-scott
