you mean after the turbo but before the bov?i think the same problems would still arise in that case. if ya mean make the mafs the last thing before the throttle body, i think that would work well. might be kinda errartic still when the tb closes though?ItzGenX wrote:So can we put the MAF before the BOV? Does a MAF work under high pressure and still able to measure the air? This should cure the "cough cough choke stall" problem eh?
Silviagirl79 wrote:Ok I just want to clear this up, because my hubby wants to buy a BOV when we install our SR (which will be temporaily running SR side mount intercooler). The question is this...It is advisable that if I am running stock everything, and stock intercooler to NOT buy an aftermarket BOV untill I buy my FMIC right?
Thnx guys.
