got2b240 »
https://forums.nicoclub.com/got2b240-u18026.html
Sat May 21, 2005 8:46 pm
DUDE
You loose boost on top end in a lower gear due to the fact our turbo cannot keep up with the rising RPM rate and CFM's its required to keep Positive pressure to the motor.
This is because the stock t-25 is small
If you boost it higher than 12, my opinion is that your killing the life of your turbo, basically cutting it in half
