redtop91 wrote:and if the problem persists, buy a T28
i agree with the 2871 idea but after owning all 3 t25 t28 and 2871(a/r .64) i wish i would have gotten something with a bigger turbine housing for better high end, less backpressure, and less detonation. the only reason i say this is because i cracked 2 of my pistons most likely because my EGT was too hot.S13FASTBACKSR wrote:
No bro he means buy a T88..Turbo lag ftw..jk but honestly if the problem is your turbo and you decide to upgrade i would spend the extra money on a 2871r .64 a/r...I wish thats what I wouldve done instead of buying a t28
what i meant was make sure you have a big enough housing to wear your engine can breathe well because back pressure can kill your motor. or you can always just run higher octane fuel which will reduce knock but with gas prices the way they are id prefer pump gas. there is nothing wrong with the 2871, i just wish i had gotten the .84 a/r instead. i didnt mean buy a huge turbo that makes 800hp at 6000 rpms. unless of course you have a built head that can handle 11,000.redtop91 wrote:Bah! Street turbos > Dyno queens.
