lexcrob wrote:Why do factory boosted engines fail when you turn up the boost. Specifically maf based cars like the rb! Is it only the fact that the injectors end up going above 80% duty and starve the engine. Or is it possibly that ignition timing is not planned for above factory boost level?
example:
Adding to that question lets assume its the fact that the injectors run out of fuel. What if you stuck a BIG T4 turbo and only ran a boost level equal to stock engine output so like 4psi. Is the factory timing adjustments and fuel only related to the (amount of air) cfm entering the engine so technically it would run fine tune wise?
Factory turbo'd engines do not fail simply because you turn up the boost. It makes no difference whether it is a carburated, fuel injected, DI, maf or speed-density system. They fail when you turn up the boost past what the stock fueling system can provide enough fuel to keep the engine from leaning out. Leaning out = detonation = BOOM! Reducing ignition timing will decrease the chance for detonation, but it will come at the sacrifice of power, so why bother turning up the boost in the first place?
And as far as installing a BIG T4 turbo and running low boost for equivalent power=equal air flow as a smaller turbo at higher boost pressure, it is possible. However, the T4 would be laggy and may surge because it is operating to the left of its surge limit. This is a really dumb idea BTW. Nobody with half a brain would do this and not add fueling and tuning upgrades.
