s14daver »
https://forums.nicoclub.com/s14daver-u26688.html
Tue May 15, 2007 6:18 pm
No, the actuator is not adjustable and no there are no leaks, i just put a new exhaust manifold gasket and manifold/turbo gasket on. BTWI checked for boost leaks just with the car running a friend revving it up...im sure i should get an actual tester so theres some actual pressure in the sytem but everything seemed sealed...ANY suggestion, and i mean anything to check would be appreciated im at my wits end trying to figure out why it wont boost properly...vacuum leak? boost leak? bad wastegate? anything come to mind at all....
