boost but no movement
black240sx96
Car: cars girls motorcycles and bmx freestyle
ok i did a search on google and here but i guess im not good at it because i didnt find anything....the problem....i wil step on the gas and the car will move and boost but not go too fast....kinda like if i step on it and hit full boost but the car will act like im just crusing....any takes ???the car: s14 s14 sr20det everything stock except FMIC and bov...thats it
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Check your timing, and check for boost leaks.
black240sx96
boro drift wrote:Check your timing, and check for boost leaks.
yeah about that...i did check for boost leaks and nothing...now...about the timing...i have the tps on .45 and the timing when the tps is connected is on the second tick mark from left to right....now when i plug the tps back on...of course after shutting off the car...i know that when checking the timing is supposed to be the send tick mark from right to left...but its not...its stilll on the second tick mark from left to right....oddly enough...but another concern of mine is when i checked the spark plugs...all four were a copper like color..instead of a white color...and these spark plug have been on for about 200 miles only....what gives...
boro drift
Make sure your timing is on the second mark from the right with the tps disconnected and idling around 850rpm.
black240sx96
boro drift wrote:Make sure your timing is on the second mark from the right with the tps disconnected and idling around 850rpm.
right to left or left to right...???
boro drift
Right to left.
black240sx96
boro drift wrote:Right to left.
yep...its there...so any idea why its not going no where ??? and why my spark plugs are a copper color...??
boro drift
Did you check for codes?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Do you have any ECU codes? Sounds like you may be running in limp mode.
Tan, or copper colored spark plugs are normal.
I would recheck your spark timing, sometimes the ECUs dont go into timing mode.
black240sx96
FlatBlackIan wrote:Do you have any ECU codes? Sounds like you may be running in limp mode.
no check engine lights...and when i tried to hook up the obd 2 to it it wouldnt read or say error...my machtec told me he couldnt hook up to it so...yeah,....
IanS
black240sx96 wrote:no check engine lights...and when i tried to hook up the obd 2 to it it wouldnt read or say error...my machtec told me he couldnt hook up to it so...yeah,....
IIRC S14SRs are not OBD 2. You will need to use the diagnostic screw on the side of the ECU. Most swaps will not activate the CEL.
black240sx96
ok....so i just learned something that i didnt read in the 816 FSM that i have looked at over 1000 times...(seriously..no joking) so ummm....what the hell do i do...you said the little screw on the side of the ecu....which i know it a really small philps screwdriver...thats about all i know about the ecu and that screw...so....yyeah...i need your help...what do i do and how do i do it and how do i know im doing it right and how do i know what code is what without the obd2 ????
IanS
Turn the key to the on position, with the engine off.
Turn the screw all the way from its current point till it stops, dont force it. There should be an LED near the screw, if it does not begin to blink turn the screw back to its original position it should begin to blink.
If there is no LED, or you cannot get it to blink, you will have to wire up the consult port, allowing you to access the ECU using a scanner.
Count the blinks, long pause = 10, and short pause = 1.
black240sx96
ok...so i need to count how many times i turn it so i know whats its original position and do i have to turn it clockwise or counter clockwise ???and if there is no led what consult port do i use and where can i find this consult port and when will it go back to normal or how do i take it out of this "mode"
IanS
The screw is a two position switch. Its either all the way clockwise, or counter clockwise. Whichever way it is, put it back there when its finished, once you start the engine, the ECU will return to normal mode.
You are counting the blinks to create a code, this code will tell you what problems the ECU has recognized.
If you get code 55, you have no issues, any other code means you have an issue.
If you cannot obtain codes, you will need to wire the factory OBD 2 consult port into the SR ECU. You said you tried to read the ECU once, it did not work because the port you plugged into, is not wired to the ECU.
black240sx96
so it is on the FSM ??? damn.....and i must have looked completely over that...thanks for the walk threw tho.
IanS
black240sx96 wrote:so it is on the FSM ??? damn.....and i must have looked completely over that...thanks for the walk threw tho.
Its not part of the normal FSM, its a sub file I do not have. Read my above post.
black240sx96
FlatBlackIan wrote:The screw is a two position switch. Its either all the way clockwise, or counter clockwise. Whichever way it is, put it back there when its finished, once you start the engine, the ECU will return to normal mode.
thats right...the obd2 wouldnt read the ecu...so in case the leds dont work then what?? because i cant connect the obd2...sorry to sound repetitive
IanS
black240sx96 wrote: in case the leds dont work then what?? because i cant connect the obd2...sorry to sound repetitive
You will need to re wire the consult port, you can find some basic instructions here. zerothread/268436
As far as wiring the consult, that should get you started, as far as talking to the ECU, you wont be able to use advanced functions, but you should at least be able to access generic OBD 2 functionality.
The whole OBD 2 thing is one reason I personally chose not to get an S14 SR, its just so much extra hassle.
black240sx96
well thank you very much...i will contact you if i fail...lol...ill let you know tomorrow
IanS
black240sx96 wrote:well thank you very much...i will contact you if i fail...lol...ill let you know tomorrow
Any time
black240sx96
problem solved...issue CAS...solution...just it get a new one
Modified by black240sx96 at 7:05 PM 9/14/2008
black240sx96
actually i didnt completely solve the problem...it seems as if it will "skip a beat" very randomly...i tried to do that ECU thing but i didnt get it...is this suposed to be the led ??
IanS
Normally there would be an LED there yes.
black240sx96
i actually started a new post on this and i realized there is no led inside the ecu...its just not there...
black240sx96
can i solder an led there ???where its supposed to be ???
black240sx96
FlatBlackIan quick question...when i turn the ecu to do its diagnostic is it possible that instead of having the led would it show the code through the check engine light itself...because i got a code from it...it blinked 3 times kinda slow then 7 times a little quicker...and i looked up the code what it could be and it side "closed loop system"...what the hell does that mean ??
Modified by black240sx96 at 4:06 AM 9/15/2008
IanS
black240sx96 wrote:FlatBlackIan quick question...when i turn the ecu to do its diagnostic is it possible that instead of having the led would it show the code through the check engine light itself...because i got a code from it...it blinked 3 times kinda slow then 7 times a little quicker...and i looked up the code what it could be and it side "closed loop system"...what the hell does that mean ??
Yes, if your CEL is hooked up it will blink the code. Im not sure what Closed loop control mean, but Id place a guess that it has something to do with the ECUs fuel control, and map switching sub routines. You may have a short in you o2 sensor circuit. Try searching the forums, also check the FSMs troubleshooting sections.
Kalypso
I saw your other thread also,
you could try soldering the LED back on,
it could work.
IanS
Kalypso123 wrote:I saw your other thread also,
it could work.
He doesnt need to, it is blinking the CEL, which does the same thing.
