boost but no movement
black240sx96
Car: cars girls motorcycles and bmx freestyle
outstanding....thanks for the help F.B.I.... lol
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
So, it was the CAS? I do have another one I can try out. The car is getting spark, but it looks weak as hell.
My timing was advanced, so it'd hit boost pretty damn early. now after I set it, it won't move when it hits boost. it'll scoot under vacuum, once it sees pressure the car's like "nuh-uhhhh"
and now I have another problem. My fuel pump fuse is blowing. I've replaced the fuse, and it'd blow after the car ran for like 3-5 seconds.
black240sx96
yeah,.. it was my CAS...once i changed it it kept my timing right...i still have a smaller problem that i dont knwo why....but it runs a lot better.
Kalypso
whats that
PantherRacer
I'm gon have to change my CAS then. I thought it was the fuel pump...as it was blowing fuses left and right etc. but it still does the same thing. luckily I still have another CAS.
black240sx96
cam angle sensor...
PantherRacer wrote:I'm gon have to change my CAS then. I thought it was the fuel pump...as it was blowing fuses left and right etc. but it still does the same thing. luckily I still have another CAS.
im just saying that was my problem...yours could be the fuel pump...check that also
PantherRacer
So...I look over everything once more...there's no *** ****** vacuum line going to the nismo Fpr! I guess something is bound to get left when you completely tear down an engine and don't make a list of what to connect when you're done, only working on it at night. and I hooked up the fpr to vacuum, still no movement under boost. Maf tests fine, still didn't try another CAS.
would the ECU have to go through any drive cycles if it was in a limp mode?
Modified by PantherRacer at 5:01 PM 10/14/2008
aznrib
Car: 1995 240sx
I stumbled upon your post and I too am having this same issue. I gm going to pull my codes to see if I get the same thing.
