i cant check codes - my potentiometer screw is broken on my ECU. My mafs wiring is 100% correct. My mafs is cleaned, and last time i checked it was giving good voltage.SideWays=smiles wrote:with MAFs unplugged I cant rev past 2500, Id say check the wiring for the MAFs and also clean it and ckeck its voltage. Are you getting any ECU codes, with the MAFs plugged in.
awesome plan...in theory. there isnt another sr in thunder baySideWays=smiles wrote:try and find a known good ECU to test with, that way you can rule it out while checking codes at the same time.
knock sensor is good and tight, new aswellFSUDrifter wrote:rich+bog @ 4k = code 34 = knock sensor
for me at least
if this doesnt fix it Ide say its time to invest in a new ECU, one that you can actually pull codes from.burntricer wrote:
im going to get another mafs and im going to also get a new plug and re-wire it. hopefullly that helps
