isnt boost afr should be high 11's to low 12's to be safe? well if you can hear the pump prime then most likely you have a bad pump or a fuelpressure regulator. have you ever upgraded your fpr? my stock fpr lasted me about 2 weeks after i installed walbro fuel pump, the car would stall out once in a while and started gettting worse every week until it died on me leaving me stranded on side of freeway. i would hear the fuel pump prime right after the car stalls out.spooled240 wrote:I dyno'd my car not too long ago but it was before I had these issues. AFR's stayed around 13 on boost. No wideband at the moment tho =/
I'm starting to think this has something to do with this Walbro pump I just installed about 1 month ago. Just driving home right now on 1/8th tank of gas I can hear my fuel pump speed up and whine whenever I brake as if the gas is sloshing around in my tank and the pump is running dry with no load and speeds up. Maybe the pump is smoked, who knows?
Yes, a bad fpr will cause it to flood and stall out. it will cause your car to feel like you have a boost leak when you give it a certain amount of gas. i remember when i give it gas it started to feel like it was stumbling and then it stalls out. Also, how do you know if you dont have enough fuel when you dont have a fuel pressure gauge and wideband? when my fpr was bad i would hear my fuel pump prime a lot. stock fpr werent made to handle the extra fuel pressure so even if that wasnt your issue, i recommend you getting something like aeromotive.spooled240 wrote:i have the stock FPR. Wouldn't a bad regulator fail to keep the fuel pressure under control though? A bad regulator would probably allow the fuel pressure to increase and flood/stall your engine. I'm having the exact opposite, not enough fuel.
yes a wideband is a must, also get a fuel pressure gauge. That sound could be detonation. Detonation sounds more like marbles in a can. Go z32 fuel filter and aftermarket fpr is a must. Installing the filter for walbro can be a bit tricky. Goooood luckspooled240 wrote:oh yeah i zip tied it on so it was going nowhere. Idk, maybe the pump got roasted.
I threw my stock pump back in and it runs good now. I did hear the "rattling" sound under my hood when the boost spiked to 13 psi again tho =/ idk maybe i need a new fuel filter or something
I decided to get some gauges next. AEM wideband, Oil pressure and Volts. The wideband will be really useful with these fuel problems.
Anyways, I get more boost when I drive down to school since the elevation is a lot lower and i'll see if I hear that sound again.
haven't checked my fuel pressure or my AFR's yet.WDRacing wrote:So far we have a host of potential issues. Just so I'm up to speed lets go over them.
No idea where your fuel pressure is under load.Stock FPR + 255lph pump.Sounds from underhood when under heavy load on boost.Bogging sometimes, detonating others.Don't know your AFRs.
Anything else?
Does it bog and detonate (making metal noise) at the same time?Pull the plugs, take a pic, post it.Check the wires, see if they are shorted or grounding out. I had an issue with mine.
WD
