oz240red »
https://forums.nicoclub.com/oz240red-u97606.html
Tue Apr 28, 2009 1:52 pm
Hey man, sorry to hear about your engine. My car will be set up almost the same as yours, my ECU is now at JWT getting reflashed and I'll be using 555cc's.
In regards to the work you're going to do, let me share what happened to me. When my car was N/A it had a bad oil pan leak. I didn't know that you could change that gasket with the engine in. It look impossible to me, so I took the engine out. When I put it back in the car was as dry as a new engine for months. When I went turbo, I took out the oil pan to weld the bong without taking the engine out. Well, no matter how careful, when putting the oil pan back in, the gasket always moves a little or gets dirty, or even if you use a little glue it comes a little loose on the corners.... in other words, it won't be as tight as changing it with the engine outside where you can clean all the residues with brake cleaner, properly distribute the glue, etc. I have changed the gasket twice already with the engine on, and it hasn't been as tight as the first time.
Since you're going to remove the head and oil pan anyways, you'll just have the block, and once out removing the transmission is cake. Plus you'll be able to inspect the cylinder walls if there was any serious damage. Might save you some troubles later bro.
Good luck
