rayj wrote:Any ideas on how to learn how to customize Torque Pro displays?
to add a specific gauge:
1. hold your finger down on any free area
(option pops up "add display")
2. pick your style of gauge you want.
3. pick the green option on the list of available sensors to gauge.
4. move the specific gauge display to the area you want.
5. tap the gauge to set it there.
(TIP) you can then push and hold the gauge display and then choose "MOVE DISPLAY" to move it if you want to nudge to either way.
(TIP) you can also change the name of a specific gauge. tap and hold your finger on any specific gauge until you see a menu with the option: "DISPLAY CONFIGURATION" then click "CHANGE TITLE" and you can type any name you want.
i have all the pages filled with these options:
page1:
large: analog RPM
small: volts, coolant
tiny: digital mpg, speed, intake temp, header cat temp, throttle position.
page2:
small: all digital gauges of the ones listed above. this way the number are easier to read
page3:
small: fuel flow, fuel status
medium: mpg
page4:
gps map of me & compass
page5:
large square: rpm, mph,
tiny digital: coolant temp, cat1b1, volts
page6:
I/M READINESS SINCE DTC CLEAR
PAGE7:
CURRENT DRIVE CYCLE STATUS
