BlackBirdVQ wrote:I thought bout pulling the motor out and doing everything to the motor while its out of the car. Winter is coming and I would most likely not drive the Q in the snow anyways, this would give me a few months of time to get the engine runing in good shape and maybe even throw some of those custom ground cams in, from australia.
If you have the time and space, I'd pull the whole engine/transmission as a unit.Having it sitting on a stand is a helluva lot easier than trying to work around the limited space in the engine compartment.
BlackBirdVQ wrote:Radiator was repleaced by the previous owner (8 years of ownership), it was a cheap aftermarket unit that was overheated a few times. I think the recepit is in the glovebox for the radiator but even then, the place where he got it repleaced at is over 100 miles away.
Since its a high mileage radiator, I doubt the manufacturer will do anything to help you. (Wishful thinking on my part, sorry.)
BlackBirdVQ wrote:My oil pan, and torque converter seal are leaking slightly (for 11 year old car its really not a leak but I am picky) so I thought of pulling the whole engine and transmission out to fix everything all at once, but I don't have the space to do a engine rebuild in and doing it at my shop where it would sit unattended at times kinda scares me. So I am still trying to decide if I wanna pull it out or do everything in the car..
You can do all of that with it in the car, but its gonna be difficult.I have more than a few scares from my endeavors.
BlackBirdVQ wrote:Did you remove the exhaust manifolds in order to pull the heads off ? Or did you remove the heads with manifolds still on them ? I know when I do HGs on Legends I never take the manifolds off. .
I unbolted the manifolds & pushed the to the side,(slightly). I didn't want to deal with replacing the gaskets at the end of the manifolds just yet.
BlackBirdVQ wrote:I haven't ordered the head gasket kit yet, cause I am not sure what else I'm going to break/need in the process of tearing the engine apart. I also do not wanna pull the heads off and find out that one of the heads is cracked, and I am stuck with a **** load of gaskets that are useless. I have few good machine shops that I personally deal with whenever I do an engine at work, so I will be giving them a call, hopping the heads check out good. .
Some cracks can be Tig welded. Warpage is another thng to look out for.Remeber they're aluminum heads.
Out of curiousity, have you looked straight down between the runners to see if you have a puddle of coolant sitting on the top of your motor?
