BlackBirdVQ »
https://forums.nicoclub.com/blackbirdvq-u32517.html
Fri Oct 14, 2005 1:02 pm
A good machine shop like I am using (build over 1000 Lexus/Toyota 3.0L V6 heads) can weld on new material and line bore the cam towers back to specs. I have been using this machine shop for years and I have NEVER had any problems with them. They acid dip the head for cleaning, and take off very little material to keep it within the FSM limits. I am sending them the heads the SAME way I got them off, WITH camshafts still bolted down to them. They will then mill the head with the cams on, perform all my needed and specified repairs- like magnafluxing it for any cracks, perform valve job if needed and install new valve seals. Heads usually come back looking like new from this company, and they are backed by a warranty.
I to have rebuild a few MB straigh 6s and V8s, my next engine job is on a 92 420SEL that needs a valve job. I know cam towers can be shimmed, but realistically, WHY ? A good machine shop is able to line bore them to perfect specs.
Line boring is a procedure of honing/borring multiple of something, like crank mains or camshaft towers. Perfectly set up honing stone goes in and makes each main or cam tower identical to the other. I get a print out of every spec on my heads, along with CFM the head flows.
Its not like I'm using a backyard mechanic to rebuild my heads, I have enough knowledge to do this myself (probably more Nissan experience than any tunner in IL), but I lack the equippment to do so. Plus I don't have the time to do this eighter.
