Blown Head Gasket? KA24E
RustyShackleford
Car: Red Piggy w/Black Meshies
I was idling the car when I noticed a hissing noise and I noticed that my coolant overfill tank was brown. Also I checked the oil and it was of a watery consistency. Are there any tests or other indicators of a blown headgasket? Thank you very much in advance. I pretty flustered over this :[
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Definitely a blown HG buddy.. Sorry :(
RustyShackleford
Alright. It's fixable. Are there any comprehensive guides for replacing a head gasket? I've searched and I came up with how-to-change-head-gasket-on-ka24-t245686.html and people recommending the FSM and Chiltons Manual.
PyR0NiAk
Pretty much your options..
RustyShackleford
Should I go ahead and do a full timing chain kit while I'm at this? Because I was reading some guides and it's saying that I gotta drop the oil pan and it's a real PITA to do the timing.
PyR0NiAk
It wouldn't be a bad idea if you have the motor out... Otherwise, yeah, it's a PITA
RustyShackleford
Alright thanks for all the help.
