TheKryptKeeper wrote:So I've been trying to get off the intake manifold collector, can I pass this step? Can I just unbolt the intake and exhaust manifold and remove the head?
Also, I heard the wedge idea, but is there a really good way to ensure that I don't drop the chain?
Krypt
Just unbolt the intake and exhaust manifolds from the head; no need to separate the intake manifold from the collector.
Before removing the cam sprocket, use nylon ties to run them through a chain link on each side; now run each nylon tie through a top hole in the timing cover, then snug up. This will hold the chain up.
