Hello, I tried searching about my issue, but didn't have too much luck. I have a 1999 Infiniti I30, and my blower motor doesn't seem to be working. It started when my blower motor was making an occasional buzzing noise, this led to it not working many months after. So far I've changed my old one out for a new one (shouldn't of done it without finding the root of the problem, but was hoping for blind luck). It didn't work at first, but I took out what I think is a relay directly below it, put it back in, then it worked for about a day. After it stopped working again, I changed out that relay, but still, no luck. The ac/heater doesn't work at any speed. When I'm driving I can feel some air coming out from my vents (not much, lower than even the lowest fan setting), but it doesn't do it when idle. As far as I can tell, there is no power going to the blower motor at all, no matter the setting there is no indication that it's even receiving the signals from the climate control. I appreciate any insight for this, thanks in advance!
