canucklehead »
https://forums.nicoclub.com/canucklehead-u105683.html
Fri May 22, 2009 2:27 pm
just an update.... if your motor only blows on one speed, usually high, then it's probably the resistor that is burnt out. My '94 maxima did this and when I read the trouble-shooting guide, there were a complicated set of directions explaining all the different ways to try and isolate the culprit. Well, mine was super simple: remove the glove box and there sits the reo-stat (or resistor). it has a recessed white plastic plug receptacle. remove plug, unscrew 2 screws and that's the culprit. it has a tiny little PC board inside with a couple of resistors on it. if you're really savy, maybe you can figure out which one of those resistors isn't working. for me, i threw out the entire part and got a used one for $40. there were several available on ebay.
