Haha, yeah, guess he hasn't learned the circular motion trick yet...boost test it for leaksCarl H wrote:while the new setup is much much cleaner, your welds on the pipes make me cry.atleast take an angle grinder to them and clean them up a bit.
t3/t4 .48a/rfly240 wrote:hey, what kind of turbo is that. How did you get it set up?.
i kept trying that with no luck. id slow down, start going good and bam, pop a hole. this is my first time playing with a welder so i really need to get into a class.Wulfgang wrote:Dude, you've got miniscule penetration on those welds. Slow down a bit or turn up the heat.
I'm trying to find out if there is a MAF of another car that would be easier to use then the stocker? (but it doesn't seem to hard now) and I was wondering why the guy in the post above ^ put the MAF before the bov after going through the trouble of making it a blow through?krayton wrote:the maf is strong enough.
lil lost on what else your asking though
the bov is after the maf300Plus wrote:I guess it was you.
which defeates the purpose of blowthru maf.bov should be placed before the maf.krayton wrote:the bov is after the maf
arggg u guys. alright im following the route backwards. pics are supposed to be worth a 1000 words here.Carl H wrote:which defeates the purpose of blowthru maf.bov should be placed before the maf.
no sirfoCk wrote:are you running the stock smic?
a blow thru system will NOT make more power but is simply a fix for erratic idle caused by bov's and high lift cams.most stock computers will allow the car to run a blowthru with no problems however there are a few which dont like to play the game so you may need a retune.if you plan on running a blow thru system, set it up before it gets tuned as if you set it up draw thru then tune to that, a blowthru is going to have diffrent results and will require a retune.scottsi wrote:so is that a rb20 or 25? what feul management are you using in order to go with a blow through system. i havent quite learned how to use a blow through system, with my setup im going to use a z32 maf, but im still somewhat undecided upon a feul management, and it seems as if a blow through maf is teh best way to go to make power so the turbo doesnt have to try to pull so much air through such a little space.
